исходящая связь
voronntl
исходящая связь
Сообщение voronntl »
Привет жители форума.
не могу понять где проблема. у меня или со стороны провайдера.
Делаю вызов на данный номер, и вот что мне выдает моя АТС:
ist trace station 381                                                 Page   1
                                LIST TRACE
time            data
10:42:48     active station    381 cid 0x8b
10:42:48     G711A ss:off ps:20
             rgn:1 [10.10.0.45]:62882
             rgn:1 [10.10.0.4]:2088
10:42:49     dial 98861 route:ARS
10:42:49     term trunk-group 12    cid 0x8b
10:42:59     dial 988613932332100# route:ARS
10:42:59     route-pattern  13 preference 1  cid 0x8b
10:42:59     seize trunk-group 12 member 3  cid 0x8b
10:42:59     Calling Number & Name NO-CPNumber NO-CPName
10:42:59     Setup digits 88613932332100
10:42:59     Calling Number & Name 74959xxxxxxx NO-CPName
10:42:59     denial event 1174: No route to dest D1=0x95c D2=0x960f03
10:42:59     route-pattern  13 preference 1 unavailable cid 0x8b
10:42:59     term trunk-group 3    cid 0x8b
10:42:59     route-pattern  13 preference 2  cid 0x8b
10:42:59     seize trunk-group 3 member 7  cid 0x8b
10:42:59     Calling Number & Name 381 User
10:42:59     Proceed trunk-group 3 member 7  cid 0x8b
10:42:59     denial event 1166: Unassigned number D1=0x95c D2=0x50101
10:42:59     idle trunk-group 3 member 7  cid 0x8b
             VOIP data from: [10.10.0.4]:2088
10:42:59     Jitter:0 0 0 0 0 0 0 0 0 0: Buff:11 WC:0 Avg:0
10:42:59     Pkloss:0 0 0 0 0 0 0 0 0 0: Oofo:0 WC:0 Avg:0
10:42:59     idle station    381 cid 0x8b
Мой ARS
hange ars analysis 1                                           Page   1 of   2
                             ARS DIGIT ANALYSIS TABLE
          Dialed           Total     Route    Call   Node  ANI
          String          Min  Max  Pattern   Type   Num   Reqd
    1                     3    3     12       pubu         n
    8                     7    25    13       pubu         n
    810                   7    25    13       pubu         n
    8375                  6    25    17       natl         n
    84852                 6    25    17       natl         n
    8495                  11   11    13       natl         n
    8495100               7    7     13       pubu         n
    8498                  11   11    13       natl         n
    8499                  11   11    17       natl         n
    8812                  6    25    17       natl         n
    89                    11   11    13       natl         n
ну и еще
change route-pattern 13                                         Page   1 of   3
                    Pattern Number: 13  Pattern Name: nov country
                             SCCAN? n     Secure SIP? n
    Grp FRL NPA Pfx Hop Toll No.  Inserted                             DCS/ IXC
    No          Mrk Lmt List Del  Digits                               QSIG
                             Dgts                                      Intw
 1: 12   0                                                              n   user
 2: 3    0                                                              n   user
 3: 1    0                                                              n   user
 4:        n   user
 5:        n   user
 6:        n   user
     BCC VALUE  TSC CA-TSC    ITC BCIE Service/Feature PARM  No. Numbering LAR
    0 1 2 M 4 W     Request                                 Dgts Format
                                                         Subaddress
 1: y y y y y n  n            rest                                         next
 2: y y y y y n  n            rest                                         none
 3: y y y y y n  n            rest                                         none
 4: y y y y y n  n            rest                                         none
 5: y y y y y n  n            rest                                         none
 6: y y y y y n  n            rest                                         none
выдает в трубке типа "сирена" гудок.
Где копать подскажите
dsh
Re: исходящая связь
Сообщение dsh »
А Вы уверены в правильности набираемого номера, вы можете прозвонится по нему например с сотового или другого оператора на через вашу атс и потом трассировка не информативна и обрезана
voronntl
Re: исходящая связь
да, с сотового дозвон есть.
voronntl
Re: исходящая связь
как трассировку сделать информативней?
dsh
Re: исходящая связь
Сообщение dsh »
Снимите трассировку через syslog - mst (web Communication Manager)
dsh
Re: исходящая связь
Сообщение dsh »
точнее Communication Manager's Message Trace Analyzer (MTA)
voronntl
Re: исходящая связь
не выдаёт никакой детализации лога, может еще можно где посмотреть?
dsh
Re: исходящая связь
Сообщение dsh »
А с провайдером вы как соединяетесь?
dsh
Re: исходящая связь
Сообщение dsh »
88613932332100 это что за номер всмысле международка?
voronntl
Re: исходящая связь
да
Re: исходящая связь
В обоих случаях вас присоединяющие операторы посылают, общайте их вопросом "Почему?"
voronntl
Re: исходящая связь
так и подумал, что у провайдера косой где то, 2 дня как решают, пока ничего сказать не могут.
Спасибо за ответы.
dsh
Re: исходящая связь
Сообщение dsh »
Возможно что провайдер по своему прав, если не ошибаюсь 886139 это краснодарский код(но тогда 11 цифр), а вы говорите что номер международка
DarkHeavy
Re: исходящая связь
Сообщение DarkHeavy »
К Оператору как подключаетесь? По какому протоколу?
