Invalid numbering format
подскажите по ошибке выхода на межгород:
22:14:39 TRACE STARTED 05/05/2019 CM Release String cold-03.0.124.0-22450
22:14:50 Calling party station 71555 cid 0x349b
22:14:50 Calling Number & Name 7XXXX ~YYYYYYY
22:14:50 dial 98914XXXXXXX# route:ARS
22:14:50 term trunk-group 1 cid 0x349b
22:14:50 route-pattern 3 preference 1 location 1/ALL cid 0x349b
22:14:50 seize trunk-group 1 member 4 cid 0x349b
22:14:50 Calling Number & Name NO-CPNumber NO-CPName
22:14:50 Setup digits 98914XXXXXXX
22:14:50 Proceed trunk-group 1 member 4 cid 0x349b
22:14:50 denial event 1186: Invalid number format D1=0xa017 D2=0x5011c
22:14:50 idle trunk-group 1 member 4 cid 0x349b
22:14:54 idle station 7XXXX cid 0x349b
Транк:
TRUNK GROUP
Group Number: 1 Group Type: isdn CDR Reports: y
Group Name: COR: 4 TN: 1 TAC: 801
Queue Length: 0
Member Assignment Method: manual
Group Type: isdn
TRUNK PARAMETERS
Charge Advice: none
Supplementary Service Protocol: b Digit Handling (in/out): enbloc/enbloc
Digital Loss Group: 18
Answer Supervision Timeout: 0
CONNECT Reliable When Call Leaves ISDN? n
XOIP Treatment: auto Delay Call Setup When Accessed Via IGAR? n
Caller ID for Service Link Call to H.323 1xC: station-extension
TRUNK FEATURES
Data Restriction? y NCA-TSC Trunk Member:
Used for DCS? n Hop Dgt? n Send EMU Visitor CPN? n
Suppress # Outpulsing? n Format: unk-pvt
Replace Restricted Numbers? n
Send Connected Number: y
Hold/Unhold Notifications? y
Send UUI IE? y Modify Tandem Calling Number: no
Send UCID? n
Send Codeset 6/7 LAI IE? y
QSIG TRUNK GROUP OPTIONS
TSC Method for Auto Callback: drop-if-possible
Diversion by Reroute? y
Path Replacement? y
Path Replacement with Retention? n
Path Replacement Method: better-route
SBS? n
Транк:
TRUNK GROUP
Queue Length: 0
Group Type: isdn
TRUNK PARAMETERS
Charge Advice: none
TRUNK FEATURES
Send UCID? n
Path Replacement? y
SBS? n
Re: Invalid numbering format
[quote="BeerHunter"]
Так и надо? Номер с 9 а АОН 7хххх ?? !!
да. звонок идет через цепочку ведомственных АТС, но именно с этой не уходит межгород.
Для МГ, обычно, требуется формат вызова nat.
если все станции так настроены, то последняя должна приводить формат номера к нужному. Может там ваша АТС не прописана?BeerHunter писал(а):да. звонок идет через цепочку ведомственных АТС, но именно с этой не уходит межгород.
ну и собственно да, в ars как межгород указан?
последовательная цепочка АТС a-b-c-d-e-МГ
при перенаправлении через транки
a-b
a-c
a-d
все тоже самое
в ars строка
89 natl
вызовы с АТС b,c,d,e на МГ идут нормально
a-b
a-c
a-d
все тоже самое
в ars строка
89 natl
Может в MST посмотреть...
а какие параметры выставить в ch mst для мониторинга?
вы получаете от удаленных станций отлуп. Пообщайтесь с админами тех станций!BeerHunter писал(а):последовательная цепочка АТС a-b-c-d-e-МГ
a-b
a-c
a-d
все тоже самое
в ars строка
89 natl
Это мои АТС, кроме e
