Всем доброго времени суток! Подскажите пожалуйста, есть следующая проблема:
Есть штука AddPac AP200 пытаюсь настроить ее с AVAYA S8500 по протоколу H.323, никогда этим не занимался, так что прошу помощи
Конфиг ap200:
version 8.238
hostname AP200
dhcp-list 0 type server
dhcp-list 0 address server interface ether0.0
dhcp-list 0 option dhcp-lease-time 600
dhcp-list 1 type server
dhcp-list 1 address server 10.1.1.2 10.1.1.126 255.255.255.128
ip-share enable
ip-share interface net-side ether0.0
ip-share interface local-side ether1.0
interface ether0.0
ip address xx.xx.xx.0 255.255.255.0
interface ether1.0
no ip address
ip dhcp-group 0
snmp name @1323@#dd
no arp reset
route xx.xx.xx.0 255.255.255.0 xx.xx.xx.xx
! VoIP configuration.
! Voice service voip configuration.
voice service voip
fax protocol t38 redundancy 0
fax rate 9600
h323 call start fast
h323 call tunnel enable
inband-ringback-tone
no busyout monitor gatekeeper
no busyout monitor callagent
busyout monitor voip-interface
! Voice port configuration.
! FXS
voice-port 0/0
! FXS
voice-port 0/1
! Pots peer configuration.
dial-peer voice 1 pots
destination-pattern 3555 (номер станции на атс с типом H.323)
port 0/1
huntstop
dial-peer voice 2 pots
destination-pattern 302
port 0/0
huntstop
! Voip peer configuration.
dial-peer voice 500 voip
destination-pattern [0-8]
session target xx.xx.xx.xx (тут я указал call server)
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 2000 voip
destination-pattern 9[0-7]T
voice-class codec 1
no vad
! Gateway configuration.
gateway
h323-id xx.xx.xx.xx (тут я указал call server)
! Codec classes configuration.
voice class codec 1
codec preference 1 g729
codec preference 2 g7231r63
codec preference 3 g7231r53
codec preference 4 g711alaw
codec preference 5 g711ulaw
! SIP UA configuration.
sip-ua
! MGCP configuration.
mgcp
codec g711ulaw
! Tones
на АТС
есть trunk-group с H.323
display trunk-group 71 Page 1 of 21
TRUNK GROUP
Group Number: 71 Group Type: isdn CDR Reports: y
Group Name: H323Galaxy COR: 1 TN: 1 TAC: 071
Queue Length: 0
Service Type: public-ntwrk Auth Code? n
Signaling Group: 71
Number of Members: 2
display trunk-group 71 Page 2 of 21
Group Type: isdn
TRUNK PARAMETERS
Charge Advice: none
Supplementary Service Protocol: a Digit Handling (in/out): enbloc/enbloc
Digital Loss Group: 18
Answer Supervision Timeout: 0
display trunk-group 71 Page 3 of 21
TRUNK FEATURES
Maintenance Tests? y
Send Name: n Send Calling Number: n
Suppress # Outpulsing? n
Replace Restricted Numbers? n
Send Connected Number: n
Send UUI IE? y
Send UCID? n
Send Codeset 6/7 LAI IE? y
display trunk-group 71 Page 5 of 21
TRUNK GROUP
Administered Members (min/max): 1/2
GROUP MEMBER ASSIGNMENTS Total Administered Members: 2
Port Name Night
1: T00121 H323Galaxy
2: T00122 H323Galaxy
3:
4:
5:
6:
7:
8:
Что дальше делать не знаю! в аппарате, который подключен к addpac, слышу длинный гудок, после набора любой цифры тишина, и соединения так и не происходит!
Проблема с настройкой AddPac AP200 c AVAYA S8500
?! а sig group ?
ну это так...
для настройки со стороны Avaya думаю поможет Configuring H.323 Signaling and IP Trunks between Avaya Communication Manager and Cisco CallManager
ну это так...
