может кто знает, проблема такая при наборе номера аон дублируется уже два дня бьюсь нечего не могу понять, может где галку снять забыл или где выставляется колличество цифр ани... вот лог...
11:40:46 tone-receiver 01AXX01 cid 0x12
11:40:46 active station 600 cid 0x12
11:40:46 dial 0659213# route:ARS
11:40:46 term trunk-group 15 cid 0x12
11:40:46 tone-receiver 01AXX05 cid 0x12
11:40:46 route-pattern 97 preference 1 cid 0x12
11:40:46 seize trunk-group 15 member 6 cid 0x12
11:40:46 Send ANI 600600 - интересует эта срока, должно уходить только 600...
11:40:49 End-of-dial cid 0x12
11:40:49 dial 0659213# route:ARS
11:40:49 ring 659213#
r2 и АОН
MULTIFREQUENCY-SIGNALING-RELATED PARAMETERS
Incoming Call Type: group-ii-mfc ANI Prefix:
Outgoing Call Type: group-ii-mfc Default ANI:
Maintenance Call Type: none NEXT ANI DIGIT
Incoming: send-ani
Outgoing: send-ani
Maximum Resend Requests:
Received Signal Gain (dB): 0
Transmitted Signal Gain (dB): -3
Request Incoming ANI (non-AAR/ARS)? y
Outgoing Forward Signal Present Timer (sec): 15
Outgoing Forward Signal Absent Timer (sec): 15
MF Signaling Intercept Treatment - Incoming? n Outgoing: tone
Collect All Digits Before Seizure? n
Overlap Sending on Link-to-Link Tandem Calls? n
Private Group II Permissions and Public Interworking? n
Use COR for All Group II Responses? n
Group II Called Party Category: user-type
Use COR for Calling Party Category? n
Request Call Category at Start of Call? n
Restart ANI from Caller Category? y
Number of Incoming ANI Digits: 15
Number of Outgoing ANI Digits: 3
Truncate Station Number in ANI: no
Address Digits Include End-of-digits Signal? n
Call Category for Vector ii-digits? n
Request CPN at Start of Call? n
Do Not Send Group B Signals to CO? n
ANI Source for Forwarded & Covered Calls: caller
INCOMING OUTGOING
ANI Available:
ANI Not Available:
INCOMING FORWARD SIGNAL TYPES INCOMING BACKWARD SIGNAL TYPES
(Tones from CO) (Tones to CO)
Group-I Group-II Group-A Group-B
11: ignored 1: normal 1 : next-digit 1 : free
12: ignored 2: normal 3 : end-of-dial 2 : busy
13: ignored 3: normal 5 : send-ani 4 : congestion
14: ignored 4: normal : 7 : intercept
15: ignored 5: normal : :
6: normal : :
7: normal : :
8: normal : :
9: normal : :
10: normal : :
11: normal : :
12: normal : :
13: normal : :
14: normal : :
15: normal : :
OUTGOING FORWARD SIGNAL TYPES OUTGOING BACKWARD SIGNAL TYPES
(Tones to CO) (Tones from CO)
12: ani-not-avail 2 : normal 1: next-digit 1: free
15: end-of-ani 5 : attendant 2: congestion 2: busy
: 6 : data-call 3: end-of-dial 3: congestion
: : 4: congestion 4: congestion
: : 5: send-ani 5: congestion
: 6: congestion 6: free
: 7: last-2-digits 7: intercept
: 8: last-3-digits 8: congestion
: 9: congestion 9: congestion
: 10: congestion 10: congestion
: 11: congestion 11: congestion
: 12: congestion 12: congestion
: 13: congestion 13: congestion
: 14: congestion 14: congestion
: 15: congestion 15: congestion
а в коре стоит Send ANI for MFE? n
Incoming: send-ani
Outgoing: send-ani
INCOMING OUTGOING
ANI Available:
ANI Not Available:
6: normal : :
7: normal : :
8: normal : :
9: normal : :
10: normal : :
11: normal : :
12: normal : :
13: normal : :
14: normal : :
15: normal : :
