Не запускается CMM
slavadvu
Не запускается CMM
Сообщение slavadvu »
Коллеги, всем доброго времени суток!
Проблема следующая:
После старта messaging появляется такой лог:
Start Messaging Software
Start Voice System information : Start of voice system completed.
Begin: start_vs Mon Feb 7 11:44:14 MSK 2011
Executing: /vs/bin/util/startup.d/audit_smdb
Using /mtce/db for dbd path instead of /vs/data/swin/db
Using /mtce/db for dbf path instead of /vs/data/swin/db
Auditing Database /vs/data/swin/db/sm_db ...
Database /vs/data/swin/db/sm_db is good.
Executing: /vs/bin/util/startup.d/chk4express
Executing: /vs/bin/util/startup.d/chk_restore
Executing: /vs/bin/util/startup.d/clrmach
Process vexLogd is not up. Check machlog package.
Насколько я понимаю, CMM запустился не до конца? Да и System Status в мэсэджинге показывает:
Server Status
System status of VM
MESSAGING OFF LINE
System status of ela
/ela/registration/sys_stat/bin/status: The enhanced list software is NOT running.
System status of iim
Internet Messaging is currently: Stopped
Percent of media space in use (contains queues): 0.0%
Number of incoming messages in queue: 0
Number of outgoing messages in queue: 0
Number of SMTP receive sessions running: 0
Number of SMTP send sessions running: 0
Number of POP3 sessions running: 0
System status of ldapolv3
----- LDAP processes -----
LDAP internal server (slapd): UP
LDAP front end server (Ldapfe): DOWN
LDAP Corporate LAN server (Ldapcorp): DOWN
----- Corporate LAN LDAP Access -----
LDAP authenticated access on the Corporate LAN: DOWN
LDAP anonymous access on the Corporate LAN: DOWN
System status of mtce
Begin System Verification Checks -
File System Capacity Check Passed
IPC queue check passed
System status of vs
Voice System is Down
Number of Purchased Voice Ports 2
Number of Voice Ports In Service 0
Available Hours of Speech 1938
Used Hours of Speech 44
Maximum Hours of Speech 1982
Number of Available Text-to-Speech Sessions 4
Все настройки делал в соответствии с мануалом СММ Installation and Initial Configuration. Switch link рассчитывал в соответствии лицензий на 5 ящиков. При установке Communication Manager галочку для massaging ставил.
Подскажите, пожалуйста, что я сделал не так?
slavadvu
Да забыл сказать про релиз - 5.2.1 с последним патчем.
