Не запускается CMM
slavadvu
Не запускается CMM
Сообщение slavadvu »
Коллеги, всем доброго времени суток!
Продолжаю крик "Help", начав его в viewtopic.php?f=1&t=2536.
Вкратце:
Система - S8800, CM 5.2.1
Все патчи, какие нашел на support для CMM 5.2.1, все поставил.
При старте massenging-а выдается такой лог:
Start Messaging Software
Start Voice System information : Start of voice system completed.
Begin: start_vs Mon Feb 7 11:44:14 MSK 2011
Executing: /vs/bin/util/startup.d/audit_smdb
Using /mtce/db for dbd path instead of /vs/data/swin/db
Using /mtce/db for dbf path instead of /vs/data/swin/db
Auditing Database /vs/data/swin/db/sm_db ...
Database /vs/data/swin/db/sm_db is good.
Executing: /vs/bin/util/startup.d/chk4express
Executing: /vs/bin/util/startup.d/chk_restore
Executing: /vs/bin/util/startup.d/clrmach
Process vexLogd is not up. Check machlog package.
Я покапался в Software Management Logs, в Messaging. Вот что нашел:
Beginning of Installation/Removal Log
Begin IA770 Automatic Installation
* Start autoinstall: Sat Feb 12 08:49:22 EST 2011 *
created /msg/software/var/sadm directory
created /msg/software/var/sadm link
created /msg/software/var/msg directory
created /msg/software/var/msg link
adding group other
adding group voice
084922 The exact autoinstall command executed was:
/usr/CHIA/autoinstall
The user was in this directory when autoinstall was executed:
The package view path variable was set to:
/usr/CHIA:
084922 swver will be installed.
084922 websrv will be installed.
084923 CHIAset will be installed.
084923 swmgmt will be installed.
084924 APPLset will be installed.
084924 us-eng will be installed.
084925 us-tdd will be installed.
084927 syseval will be installed.
084927 migration-IA51-IALX will be installed.
084927 The following packages will be installed:
swver websrv mom mtce vs maint prismlog machlog cdhstub swtts perf cswebadm webvoice swinbase chiaweb teladm tscrtu h323 chia CHIAset swmgmt FastObjects-t7_9.5-OpenSSL FastObjects-t7_9.5-RuntimeSystem FastObjects-t7_9.5-Tools VM-dfltdb VM-sw ldapolv3 iim ela perldap emf-tts MessagingLocale APPLset us-eng us-tdd syseval migration-IA51-IALX
084927 The Call Processing system is already stopped.
Continuing with package installation.
084927 - begin installing swver 5.2.1-13.0.
error: failed to open /etc/mtab: No such file or directory
084927 - installation succeeded swver 5.2.1-13.0.
084927 - begin installing websrv 13.017-00.00.003.
Updating the httpd.conf files
/opt/ecs/web/msg/./includes/msgContent.php
/opt/ecs/web/msg/./msgRedir.php
/opt/ecs/web/msg/./w_msgMain.php
14 blocks
/opt/ecs/web/prp/msg/./en/msgTitle.dat
/opt/ecs/web/prp/msg/./en/w_msgMain.dat
1 block
084928 - installation succeeded websrv 13.017-00.00.003.
084928 - begin installing mom 13.017-00.00.003.
084928 - installation succeeded mom 13.017-00.00.003.
084928 - begin installing mtce 13.017-00.00.003.
Register mtce with the Maintenance Module
Incorporate process file into inittab
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "en_US.UTF8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Меня смущает строчка:
Т.е. если я правильно понял отсутствует директория или файл /etc/mtab.
Всю систему заново переустановил повторно - Не помогло. Перезапуск сервера, disable/enable messaging - тоже не помогает.
В чем может быть проблема?
В заранее всем спасибо!
svyazist
Re: Не запускается CMM
Сообщение svyazist »
Та же самая проблема с этим релизом, вы как то решили её?
shrike
Сообщение shrike »
нам в Комптеке рассказывали что не стоит увлекаться установкой самых последних релизов...
