Как лучше убрать 9
anchor
Как лучше убрать 9
Сообщение anchor »
Приветствую.
От руководства поступила задача убрать 9 при наборе внешних номеров.
Я вижу пока только 1 вариант решения задачи - все разруливать в AAR. Но это как-то получается не совсем логично.
Дайте совет как лучше это реализовать.
SpbPavel
Re: Как лучше убрать 9
Сообщение SpbPavel »
Не знаю, у меня через ars anal.
"all","0x","2","2","1","pubu",""
"all","0xx","3","3","1","pubu",""
"all","1xx","3","3","1","pubu",""
"all","3xxxxxx","7","7","1","pubu",""
"all","4xxxxxx","7","7","1","pubu",""
"all","5xxxxxx","7","7","1","pubu",""
"all","6xxxxxx","7","7","1","pubu",""
"all","7xxxxxx","7","7","1","pubu",""
"all","80xxxxxxxxx","11","11","2","pubu",""
"all","810","12","12","3","pubu",""
"all","810","13","13","3","pubu",""
"all","810","14","14","3","pubu",""
"all","810","15","15","3","pubu",""
"all","810","16","16","3","pubu",""
"all","810","17","17","3","pubu",""
"all","810","18","18","3","pubu",""
"all","811xxxxxxxx","11","11","2","pubu",""
"all","812xxxxxxxx","11","11","2","pubu",""
"all","813xxxxxxxx","11","11","2","pubu",""
"all","814xxxxxxxx","11","11","2","pubu",""
"all","815xxxxxxxx","11","11","2","pubu",""
"all","816xxxxxxxx","11","11","2","pubu",""
"all","817xxxxxxxx","11","11","2","pubu",""
"all","818xxxxxxxx","11","11","2","pubu",""
"all","819xxxxxxxx","11","11","2","pubu",""
"all","82xxxxxxxxx","11","11","2","pubu",""
"all","83xxxxxxxxx","11","11","2","pubu",""
"all","84xxxxxxxxx","11","11","2","pubu",""
"all","85xxxxxxxxx","11","11","2","pubu",""
"all","86xxxxxxxxx","11","11","2","pubu",""
"all","87xxxxxxxxx","11","11","2","pubu",""
"all","88xxxxxxxxx","11","11","2","pubu",""
"all","89xxxxxxxxx","11","11","2","pubu",""
"all","9xxxxxx","7","7","1","pubu",""
А в dialplan anal - все, кроме 1, привязано к ars.
С уважением Павел С.
Приходите за помощью - http://forum.tecom.ru
SpbPavel писал(а):Не знаю, у меня через ars anal.
а как городские номера 1хххххх набираются?
anchor
Сообщение anchor »
Можно увидеть dialplan anal?
SpbPavel
А у меня в Питере их нетути :-)
А что анал, там проще некуда, вот:
0 1 ars
12 4 ext
19 3 fac
2 1 ars
3 1 ars
9 1 ars
* 1 fac
anchor
Сообщение anchor »
0 1 ars
12 4 ext
19 3 fac
2 1 ars
3 1 ars
9 1 ars
* 1 fac
Что означает например запись "2 1 ars"?
Нажимая 2 длиной в 1 символ я попадаю в ars таблицу, где расписан весь анализ.
Т.е. набрав 7-мизначный городской номер 2123456 в ars-анализ попадет только 123456?
SpbPavel
Почему, 2 из диалплана тоже попадет.
2 - первая цифра, 1 - длина анализа, уйдет в ARS.
А там написано, что "2xxxxxx","7","7","1","pubu", номера на 2 длиной 7 - в Route Pattern 1.
К Route Pattern привязана Trunk Group, и полетело в город.
dadoo
Сообщение dadoo »
А может чуть проще - ARS/AAR Dialing without FAC? Или закрыто?
shrike
Сообщение shrike »
а если сделать так чтоб при поднятии трубки 9 набиралась автоматом? (не спрашивайте как сделать - не помню, но знаю точно - сделать можно) ...
UPD
но это если все звонят только на внешку...
michael_loginov
Сообщение michael_loginov »
shrike писал(а):а если сделать так чтоб при поднятии трубки 9 набиралась автоматом? (не спрашивайте как сделать - не помню, но знаю точно - сделать можно) ...
UPD
есть такая вещь как ENHANCED LOCAL DIALING RULES в 46xxxsettings и где то через АСА это тоже можно править, не помню уже какой объект.
по крайней мере софтфон у меня эти правила набора берет без проблем и номера внешние можно набирать без 9-ки, он сам ее подставит.
anchor
Сообщение anchor »
UPD
Помню когда-то это делал для какой-то заказчика небольшого. Но тогда будут недоступны FAC после поднятия трубки. Это не подходит.
ARS/AAR Dialing without FAC открыто только на одной узловой станции S8710. На всех остальных CSI закрыто. Не подходит.
anchor
Сообщение anchor »
SpbPavel писал(а):Почему, 2 из диалплана тоже попадет.
В диалплане у тебя говорится, что последовательность с 2 длиной в одну цифру отправлять в ARS-таблицу.
Все не понятно почему последовательность из 7-ми цифр (ну к примеру городской 7мизначный номер) 2хххххх должна попасть в ARS?
Вот если написать, что 2 7 ars, то тогда все ясно. Я могу в поле длины указать максимум 7 цифр. Но есть еще сотовые и международные номера.
dadoo
Сообщение dadoo »
В ars получится строка не 2хххххх, а:
1ххххх 6 6 pubu rout N > rout N insert dig 2 > trunk (на всякий) overlap
2...
3...
9...
0...
И соответственно так для каждой цифры.
Межгород и сотовые проще, там все через 8, 8 использовать как FAC AAR.
Но остается проблема, внутренних номеров и TAC. Если внутренние номера еще можно отсеивать в ars dig-conv, то с TAC сложнее, но можно его пробовать на *или #.
Попробовать нет возможности, сейчас ужо дома.
SpbPavel
anchor писал(а): В диалплане у тебя говорится, что последовательность с 2 длиной в одну цифру отправлять в ARS-таблицу.
Для анализа достаточно одной цифры.
2 с длиной 1 включит ARS, все 7 цифр проанализируются в ars anal.
Конфиг рабочей узловой АТС небольшого провайдера.
Делайте так.
