На станции R013x.01.1.628.7 (Release String: S8300-013-01.1.628.7) настроен сбор данных CDR.
При наборе международного номера как "00 код-страны код-города номер"
в CDR появляется запись где dialed-number полностью записан.
190411 1414 00318 455 00357хххххххх 455 0 201 7
номер целиком с кодом оправляется в транк:
11:28:26 dial 0101800357хххххххх# route:IXC|ARS
11:28:26 route-pattern 1 preference 1 cid 0xf0
11:28:26 seize trunk-group 1 member 19 cid 0xf0
11:28:26 Setup digits 57хххххххх
11:28:26 Calling Number & Name NO-CPNumber Anastasiia Te
11:28:26 Proceed trunk-group 1 member 19 cid 0xf0
11:28:34 Alert trunk-group 1 member 19 cid 0xf0
11:28:48 idle station 455 cid 0xf0
200411 1128 00126 455 57хххххх 455 0 201 7
Буду благодарна за любые подсказки)
change system-parameters cdr Page 1 of 2
CDR SYSTEM PARAMETERS
Node Number (Local PBX ID): CDR Date Format: day/month
Primary Output Format: customized Primary Output Endpoint: CDR2
Secondary Output Format: customized Secondary Output Endpoint: CDR1
Use ISDN Layouts? n
Use Enhanced Formats? n Condition Code 'T' For Redirected Calls? y
Modified Circuit ID Display? n Remove # From Called Number? y
Record Outgoing Calls Only? n Intra-switch CDR? y
Suppress CDR for Ineffective Call Attempts? n Outg Trk Call Splitting? y
Disconnect Information in Place of FRL? y Outg Attd Call Record? y
Interworking Feat-flag? y
Record Called Vector Directory Number Instead of Group or Member? n
Record Agent ID on Incoming? y Record Agent ID on Outgoing? y
Inc Trk Call Splitting? y Inc Attd Call Record? y
Record Non-Call-Assoc TSC? y Call Record Handling Option: warning
Record Call-Assoc TSC? y Digits to Record for Outgoing Calls: dialed
Privacy - Digits to Hide: 0 CDR Account Code Length: 15
change system-parameters cdr Page 2 of 2
Data Item - Length Data Item - Length Data Item - Length
1: date - 6 17: space - 1 33: -
2: space - 1 18: cond-code - 1 34: -
3: time - 4 19: space - 1 35: -
4: space - 1 20: auth-code - 13 36: -
5: sec-dur - 5 21: return - 1 37: -
6: space - 1 22: - 38: -
7: clg-num/in-tac - 15 23: - 39: -
8: space - 1 24: - 40: -
9: dialed-num - 23 25: - 41: -
10: calling-num - 15 26: - 42: -
11: space - 1 27: - 43: -
12: in-trk-code - 4 28: - 44: -
13: space - 1 29: - 45: -
14: code-dial - 4 30: - 46: -
15: space - 1 31: - 47: -
16: code-used - 4 32: - 48: -
change route-pattern 1 Page 1 of 3
Pattern Number: 1 Pattern Name:
SCCAN? n Secure SIP? n
Dgts Intw
1: 1 1 n user
change trunk-group 1 Page 1 of 21
TRUNK GROUP
Group Number: 1 Group Type: isdn CDR Reports: y
Group Name: OUTSIDE CALL COR: 95 TN: 1 TAC: 201
Queue Length: 0
Far End Test Line No:
TestCall BCC: 4
change trunk-group 1 Page 2 of 21
Group Type: isdn
TRUNK PARAMETERS
Max Message Size to Send: 260 Charge Advice: automatic
Trunk Hunt: cyclical
Digital Loss Group: 13
Answer Supervision Timeout: 0
change trunk-group 1 Page 3 of 21
TRUNK FEATURES
Maintenance Tests? y
Data Restriction? n NCA-TSC Trunk Member: 1
Charge Conversion: 1
Decimal Point: none Replace Restricted Numbers? n
Currency Symbol: Cyp Replace Unavailable Numbers? n
Charge Type: units Send Connected Number: y
Send UUI IE? y Modify Tandem Calling Number? n
Send UCID? n
Apply Local Ringback? n
change signaling-group 1 Page 1 of 5
SIGNALING GROUP
Group Number: 1 Group Type: isdn-pri
Associated Signaling? y Max number of NCA TSC: 3
Primary D-Channel: 001V216 Max number of CA TSC: 3
Trunk Group for NCA TSC: 1
Trunk Group for Channel Selection: 1
Supplementary Service Protocol: a Network Call Transfer? n
