Доброго дня!
Смигрировали с 4 на 6-ку поимели чаcть проблем, одна из которых коснулась CDR
change system-parameters cdr Page 1 of 2
CDR SYSTEM PARAMETERS
Node Number (Local PBX ID): 2 CDR Date Format: day/month
Primary Output Format: customized Primary Output Endpoint: CDR1
Secondary Output Format: customized Secondary Output Endpoint: CDR2
Use ISDN Layouts? n Enable CDR Storage on Disk? y
Use Enhanced Formats? n Condition Code 'T' For Redirected Calls? n
Use Legacy CDR Formats? y Remove # From Called Number? y
Modified Circuit ID Display? n Intra-switch CDR? y
Record Outgoing Calls Only? n Outg Trk Call Splitting? y
Suppress CDR for Ineffective Call Attempts? y Outg Attd Call Record? n
Disconnect Information in Place of FRL? n Interworking Feat-flag? n
Record Called Vector Directory Number Instead of Group or Member? n
Record Agent ID on Incoming? y Record Agent ID on Outgoing? y
Inc Trk Call Splitting? y Inc Attd Call Record? y
Record Non-Call-Assoc TSC? n Call Record Handling Option: warning
Record Call-Assoc TSC? n Digits to Record for Outgoing Calls: dialed
Privacy - Digits to Hide: 0 CDR Account Code Length: 15
change system-parameters cdr Page 2 of 2
Data Item - Length Data Item - Length Data Item - Length
1: date - 6 17: line-feed - 1 33: -
2: space - 1 18: - 34: -
3: time - 4 19: - 35: -
4: space - 1 20: - 36: -
5: sec-dur - 5 21: - 37: -
6: space - 1 22: - 38: -
7: in-trk-code - 4 23: - 39: -
8: in-crt-id - 3 24: - 40: -
9: space - 1 25: - 41: -
10: code-used - 4 26: - 42: -
11: out-crt-id - 3 27: - 43: -
12: space - 1 28: - 44: -
13: clg-num/in-tac - 15 29: - 45: -
14: space - 1 30: - 46: -
15: dialed-num - 23 31: - 47: -
16: return - 1 32: - 48: -
Record length = 75
При входящем вызове поле in-trk-code остается пустым, а не как ранее, пример 0002 ( TAC ). Данный параметр для нас критичен, может кто сталкивался с этим?
CM6 проблема с CDR, нет части информации
vsorokin
Re: CM6 проблема с CDR, нет части информации
Аналогичная проблема наблюдалась у меня при транзитах с IP в ISDN и обратно.
Здесь в третьей строке пропал ТАС 7010.
Так и не понял толком, в чем дело было. Напрямую с CDR это вроде не связано.
Путем не помню уже каких манипуляций (скорее всего - с транками) убрал отдачу таких строк.
260110 0905 00013 7010008 84952509907 7003 9 0
260110 0911 00631 7010008 84952509907 6859631 9 2
260110 0911 00631 008 7003002 6859631 11264 7 1
Нашел ответ. Это баг и в 3-ем сервис паке он исправлен. Отсутсвие параметра inc-trk-code в кастомизированном CDR. Жаль только не сможем поставить данный сервис пак, так как начиная со второго есть баг в bcms по VDN.
