Всем доброго времени суток.
настроил транк s8300 и Сisco 2851.
Существует проблема внутренних вызовов со стороны Cisco к S8300
Слышу звонок поднимаю трубку - в ответ просто тишина(на той стороне меня слышат). Ip связность присутствует. С исходящими вызовами все порядке!
Подскажите пожалуйста в чем может быть дело.
Трассировка звонка:
15:39:13 Calling party trunk-group 52 member 1 cid 0x67
15:39:13 Calling Number & Name NO-CPNumber NO-CPName
15:39:13 active trunk-group 52 member 1 cid 0x67
15:39:13 dial 77787
15:39:13 ring station 77787 cid 0x67
15:39:13 G711A ss:off ps:20
rgn:1 [10.129.150.212]:13884
rgn:1 [10.77.1.10]:2050
15:39:13 G729 ss:off ps:20
rgn:2 [172.18.1.3]:17208
rgn:1 [10.77.1.10]:2058
15:39:13 xoip options: fax:Relay modem:off tty:US uid:0x50053
xoip ip: [10.77.1.10]:2058
15:39:15 active station 77787 cid 0x67
15:39:15 G729A ss:off ps:20
15:39:15 G729 ss:off ps:20
15:39:20 idle station 77787 cid 0x67
Настройка сигнальной группы:
change signaling-group 52 Page 1 of 6
SIGNALING GROUP
Group Number: 52 Group Type: h.323
SBS? n Remote Office? n Max number of NCA TSC: 8
Q-SIP? n Max number of CA TSC: 8
IP Video? n Trunk Group for NCA TSC: 52
Trunk Group for Channel Selection: 52 X-Mobility/Wireless Type: NONE
TSC Supplementary Service Protocol: a Network Call Transfer? n
T303 Timer(sec): 10
H.245 DTMF Signal Tone Duration(msec):
Near-end Node Name: procr Far-end Node Name: pfo.nijniyn
Near-end Listen Port: 1720 Far-end Listen Port: 1720
Far-end Network Region: 2
LRQ Required? n Calls Share IP Signaling Connection? n
RRQ Required? n
Bypass If IP Threshold Exceeded? y
H.235 Annex H Required? n
DTMF over IP: out-of-band Direct IP-IP Audio Connections? y
Link Loss Delay Timer(sec): 90 IP Audio Hairpinning? n
Enable Layer 3 Test? n Interworking Message: PROGress
H.323 Station Outgoing Direct Media? y DCP/Analog Bearer Capability: 3.1kHz
Настройка транка:
change trunk-group 52 Page 1 of 21
TRUNK GROUP
Group Number: 52 Group Type: isdn CDR Reports: y
Group Name: pro.nijniyn COR: 1 TN: 1 TAC: *52
Queue Length: 0
Signaling Group: 52
Number of Members: 8
change trunk-group 52 Page 2 of 21
Group Type: isdn
TRUNK PARAMETERS
Charge Advice: none
Supplementary Service Protocol: a Digit Handling (in/out): enbloc/enbloc
Digital Loss Group: 18
Answer Supervision Timeout: 0
CONNECT Reliable When Call Leaves ISDN? n
XOIP Treatment: auto Delay Call Setup When Accessed Via IGAR? n
change trunk-group 52 Page 3 of 21
TRUNK FEATURES
Suppress # Outpulsing? n Format: private
Replace Restricted Numbers? n
Send Connected Number: n
Send UUI IE? y Modify Tandem Calling Number: no
Send UCID? n
Send Codeset 6/7 LAI IE? y
Изначально исходящие звонки тоже не проходили но при включении "H323 Station Outgoing Direct Media y" исходящие звонки в строну Cisco "починились". За что отвечает данная опция?
H.323 Trunk S8300 vs Cisco
Re: H.323 Trunk S8300 vs Cisco
в первом регионе G711, во втором G729. Порты разные. Какой кодек прописан на 3й странице в network-region 1 <-> 2? такое чувство, что никакой.dokilopik писал(а): rgn:2 [172.18.1.3]:17208
"H323 Station Outgoing Direct Media y" - A call from an H.323 station over a trunk that uses this signaling group
starts as a direct media call. The IP address and port of the H.323 station
are sent as the media and media control channel addresses in the
SETUP/INVITE message.
Note:
On an outgoing Direct Media call from an IP (H.323) telephone over
this trunk, if an attempt is made to transfer the call, conference another
party, or put the call on hold while the call is still in ringing state, the
operation fails.
Проверьте, что у вас корректно настроена маршрутизация между этими устройствами, включая конечные ip-ip.dokilopik писал(а):Всем доброго времени суток.
Трассировка звонка:
15:39:13 dial 77787
SIGNALING GROUP
T303 Timer(sec): 10
RRQ Required? n
Настройка транка:
TRUNK GROUP
Queue Length: 0
Signaling Group: 52
Group Type: isdn
TRUNK PARAMETERS
Charge Advice: none
TRUNK FEATURES
Send UCID? n
Указал одинаковые кодеки в регионах - заработало.
Спасибо за помощь!
Спасибо за помощь!
