При входящем вызове с Yeastar на 1608 высвечивается номер абонента "Petrov 3112". Как только поднимают трубку сразу меняется на название транка "SIP_TRUNK1". В принятых вызовах тоже название транка.
Кто-нибудь знает как исправить?
11:06:38 SIP<INVITE sip:1133@10.221.21.250:5060;transport=tcp S
11:06:38 SIP<IP/2.0
11:06:38 SIP>SIP/2.0 180 Ringing
11:06:38 Calling party trunk-group 15 member 1 cid 0x224
11:06:38 Calling Number & Name 3112 Petrov
11:06:38 dial 1133
11:06:38 ring station 1133 cid 0x224
11:06:38 G711A ss:off ps:20
rgn:1 [10.221.21.49]:3170
rgn:1 [10.221.21.251]:2064
rgn:5 [10.200.1.15]:11298
rgn:1 [10.221.21.251]:2058
11:06:38 xoip options: fax:T38 modem:PT tty:PT uid:0x50027
xoip ip: [10.221.21.251]:2058
11:06:41 SIP>SIP/2.0 200 OK
11:06:41 active station 1133 cid 0x224
11:06:41 SIP<ACK sip:10.221.21.250;transport=tcp SIP/2.0
11:06:41 SIP>INVITE sip:3112@10.200.1.15:44892;transport=TCP SIP
11:06:41 SIP>/2.0
11:06:41 SIP<SIP/2.0 200 OK
11:06:41 SIP>UPDATE sip:unknown@10.200.1.15:44892;transport=TCP
11:06:41 SIP>ACK sip:unknown@10.200.1.15:44892;transport=TCP SIP
11:06:41 SIP>/2.0
11:06:41 G711A ss:off ps:20
11:06:44 SIP>BYE sip:unknown@10.200.1.15:44892;transport=TCP SIP
11:06:44 SIP>/2.0
11:06:44 idle station 1133 cid 0x224
display trunk-group 15 Page 1 of 21
TRUNK GROUP
Group Number: 15 Group Type: sip CDR Reports: r
Group Name: SIP_TRUNK1 COR: 1 TN: 1 TAC: 7715
Dial Access? n Night Service:
Queue Length: 0
Signaling Group: 4
Number of Members: 30
display trunk-group 15 Page 2 of 21
Group Type: sip
TRUNK PARAMETERS
Unicode Name: auto
Redirect On OPTIM Failure: 5000
SCCAN? n Digital Loss Group: 18
Preferred Minimum Session Refresh Interval(sec): 600
display trunk-group 15 Page 3 of 21
TRUNK FEATURES
Maintenance Tests? y
Numbering Format: public
UUI Treatment: service-provider
Replace Restricted Numbers? n
Show ANSWERED BY on Display? n
display trunk-group 15 Page 4 of 21
PROTOCOL VARIATIONS
Mark Users as Phone? y
Prepend '+' to Calling Number? n
Send Transferring Party Information? n
Send Diversion Header? n
Support Request History? n
Telephone Event Payload Type:
display signaling-group 4
SIGNALING GROUP
Group Number: 4 Group Type: sip
Transport Method: tcp
IMS Enabled? n Co-Resident SES? n
Near-end Node Name: procr Far-end Node Name: yeastar
Near-end Listen Port: 5060 Far-end Listen Port: 5060
Far-end Network Region: 5
Far-end Domain: 10.200.1.15
Bypass If IP Threshold Exceeded? n
Incoming Dialog Loopbacks: eliminate RFC 3389 Comfort Noise? n
DTMF over IP: rtp-payload Direct IP-IP Audio Connections? y
Session Establishment Timer(min): 3 IP Audio Hairpinning? n
Enable Layer 3 Test? n Direct IP-IP Early Media? n
H.323 Station Outgoing Direct Media? n Alternate Route Timer(sec): 6
display ip-network-region 5 Page 1 of 19
IP NETWORK REGION
Region: 5
MEDIA PARAMETERS Intra-region IP-IP Direct Audio: yes
Codec Set: 1 Inter-region IP-IP Direct Audio: yes
UDP Port Min: 2048 IP Audio Hairpinning? n
UDP Port Max: 3329
DIFFSERV/TOS PARAMETERS RTCP Reporting Enabled? y
Call Control PHB Value: 46 RTCP MONITOR SERVER PARAMETERS
Audio PHB Value: 46 Use Default Server Parameters? y
Video PHB Value: 26
802.1P/Q PARAMETERS
Call Control 802.1p Priority: 6
Audio 802.1p Priority: 6
Video 802.1p Priority: 5 AUDIO RESOURCE RESERVATION PARAMETERS
H.323 IP ENDPOINTS RSVP Enabled? n
H.323 Link Bounce Recovery? y
Keep-Alive Interval (sec): 5
Keep-Alive Count: 5
IP NETWORK REGION
INTER-GATEWAY ALTERNATE ROUTING / DIAL PLAN TRANSPARENCY
Incoming LDN Extension:
Conversion To Full Public Number - Delete: Insert:
Maximum Number of Trunks to Use for IGAR:
Dial Plan Transparency in Survivable Mode? n
BACKUP SERVERS(IN PRIORITY ORDER) H.323 SECURITY PROFILES
1 1 challenge
2 2
3 3
4 4
5
6 Allow SIP URI Conversion? y
TCP SIGNALING LINK ESTABLISHMENT FOR AVAYA H.323 ENDPOINTS
Near End Establishes TCP Signaling Socket? y
Near End TCP Port Min: 61440
Near End TCP Port Max: 61444
Source Region: 5 Inter Network Region Connection Management I M
G A t
dst codec direct WAN-BW-limits Video Intervening Dyn A G c
rgn set WAN Units Total Norm Prio Shr Regions CAC R L e
1 1 y NoLimit n t
2 1 y NoLimit n all t
3 3 y NoLimit n all t
4 2 y NoLimit n t
5 1 all
6 1 y NoLimit n t
7
8
9
10
11
12
13
14
15
И на исходящую может ли Avaya сразу получить название абонента с Yeastar? При исходящих только номер абонента.
list trace station 1133 Page 1
LIST TRACE
time data
11:56:58 active station 1133 cid 0x178
11:56:58 G711A ss:off ps:20
rgn:1 [10.221.21.251]:2076
11:56:59 dial 3112 route:UDP|AAR
11:56:59 term trunk-group 15 cid 0x178
11:56:59 route-pattern 15 preference 1 cid 0x178
11:56:59 seize trunk-group 15 member 19 cid 0x178
11:56:59 Calling Number & Name NO-CPNumber NO-CPName
11:56:59 SIP>INVITE sip:3112@10.200.1.15;user=phone SIP/2.0
11:56:59 Setup digits 3112
11:56:59 Calling Number & Name NO-CPNumber Yakovlev Niko
11:56:59 SIP<SIP/2.0 100 Trying
11:56:59 Proceed trunk-group 15 member 19 cid 0x178
11:56:59 SIP<SIP/2.0 180 Ringing
11:56:59 Alert trunk-group 15 member 19 cid 0x178
11:57:03 SIP<SIP/2.0 200 OK
11:57:03 SIP>ACK sip:3112@10.200.1.15:5060;transport=TCP SIP/2.0
11:57:03 active trunk-group 15 member 19 cid 0x178
11:57:03 G711A ss:off ps:20
rgn:5 [10.200.1.15]:10462
rgn:1 [10.221.21.251]:2084
11:57:03 xoip options: fax:T38 modem:PT tty:PT uid:0x50039
xoip ip: [10.221.21.251]:2084
11:57:03 SIP>INVITE sip:3112@10.200.1.15:5060;transport=TCP SIP/
11:57:03 SIP>2.0
11:57:03 SIP>ACK sip:10.200.1.15:5060;transport=TCP SIP/2.0
11:57:09 SIP<BYE sip:10.221.21.250;transport=tcp SIP/2.0
11:57:09 SIP>SIP/2.0 200 OK
11:57:09 idle trunk-group 15 member 19 cid 0x178
11:57:09 G711A ss:off ps:20
rgn:1 [10.221.21.251]:2060
11:57:09 idle station 1133 cid 0x17b
Заранее благодарю! С уважением!
Название абонента при входящем звонкейцу
