Добрый день,
Подключен телефон 9640 с модулем расширения SMB24. Есть необходимость поменять наименование кнопок на модуле, но по инструкции не выходит.
1. Press “Avaya menu” button on your phone [ A ]
2. Press “right navigation button” [ > ], and then “bottom navigation” [ V ] to choose “Application Settings” menu.
3. Press [ Select ]
4. Press “bottom navigation” [ V ] to choose “Personalize Labels…” option.
5. Press [Change]
6. Use “right navigation button” [ > ] to scroll phone buttons labels, after them should be module buttons labels
7. Choose necessary and press [Edit].
На шестом пункте кнопок модуля не видно, отображаются только кнопки телефона.
Встречалась ли кому-то такая проблемма и как с ней бороться?
Заранее благодарю.
Настройки станции:
change station 23312 Page 1 of 6
STATION
Extension: 23312 Lock Messages? n BCC: 0
Type: 9640 Security Code: * TN: 1
Port: S00176 Coverage Path 1: 1 COR: 1
Name: Ext23312 Coverage Path 2: COS: 1
Hunt-to Station:
STATION OPTIONS
Time of Day Lock Table:
Loss Group: 19 Personalized Ringing Pattern: 1
Message Lamp Ext: 23312
Speakerphone: 2-way Mute Button Enabled? y
Display Language: english Button Modules: 1
Survivable GK Node Name:
Survivable COR: internal Media Complex Ext:
Survivable Trunk Dest? y IP SoftPhone? n
Customizable Labels? y
change station 23312 Page 2 of 6
STATION
FEATURE OPTIONS
LWC Reception: spe Auto Select Any Idle Appearance? n
LWC Activation? y Coverage Msg Retrieval? y
LWC Log External Calls? n Auto Answer: none
CDR Privacy? n Data Restriction? n
Redirect Notification? y Idle Appearance Preference? n
Per Button Ring Control? n Bridged Idle Line Preference? n
Bridged Call Alerting? n Restrict Last Appearance? y
Active Station Ringing: single
EMU Login Allowed? n
H.320 Conversion? n Per Station CPN - Send Calling Number? y
Service Link Mode: as-needed EC500 State: enabled
Multimedia Mode: enhanced Audible Message Waiting? n
MWI Served User Type: qsig-mwi Display Client Redirection? n
Select Last Used Appearance? n
Coverage After Forwarding? s
Multimedia Early Answer? n
Direct IP-IP Audio Connections? y
Emergency Location Ext: 23312 Always Use? n IP Audio Hairpinning? n
change station 23312 Page 3 of 6
STATION
Conf/Trans on Primary Appearance? n
Bridged Appearance Origination Restriction? n
Call Appearance Display Format: disp-param-default
IP Phone Group ID:
ENHANCED CALL FORWARDING
Forwarded Destination Active
Unconditional For Internal Calls To: n
External Calls To: n
Busy For Internal Calls To: n
No Reply For Internal Calls To: n
SAC/CF Override: n
change station 23312 Page 4 of 6
STATION
SITE DATA
Room: Europe Headset? n
Jack: Speaker? n
Cable: Mounting: d
Floor: Cord Length: 0
Building: Set Color:
ABBREVIATED DIALING
List1: enhanced 1 List2: system List3: personal 1
BUTTON ASSIGNMENTS
1: call-appr 5: send-calls Ext:
2: call-appr 6: call-fwd Ext:
3: call-appr 7: directory
4: call-pkup P:h Rg:no-ring 8: next
voice-mail Number: 24499~p#
change station 23312 Page 5 of 6
STATION
BUTTON ASSIGNMENTS
9: call-disp
10: goto-cover
11: brdg-appr B:1 E:23311
12: brdg-appr B:1 E:23306
13:
14:
15:
16:
17:
18:
19:
20:
21:
22:
23:
24:
change station 23312 Page 6 of 6
STATION
BUTTON MODULE #1 ASSIGNMENTS
1: busy-ind TAC/Ext: 23311 13:
2: busy-ind TAC/Ext: 23313 14:
3: busy-ind TAC/Ext: 23316 15:
4: busy-ind TAC/Ext: 23318 16:
5: busy-ind TAC/Ext: 23315 17:
6: busy-ind TAC/Ext: 23314 18:
7: autodial Number: 902079027776# 19:
8: autodial Number: 902076124040# 20:
9: busy-ind TAC/Ext: 23306 21:
10: 22:
11: 23:
12: 24:
SMB24 переименование кнопок
Re: SMB24 переименование кнопок
1. Версия прошивки какая?
2. OPSTAT как стоит?
3. BRURI не забыли прописать?
4. Сохранение вручную проходит?
