Добрый день господа.
Вопрос такой. Возможно ли устроить удалённый доступ к администрированию Ipo из другой подсети??
Варианты типа "Поставить в эту подсеть компьютер и соединяться по РДП" не подходят.
Avaya IPO 406 удалённый доступ
Если прямой IP, то проблем быть не должно, во всяком случае у меня не было. Если через NAT, то в Манагере есть встроенный хелп и можно посмотреть какие порты используются для каких приложений, например (некоторые из них):
50794
IPO Monitor
UDP
From the IP Office Monitor application.
50795
IPO Voice Networking
UDP
Small Community Network signalling (AVRIP) and BLF updates. Each system does a broadcast every 30 seconds. BLF updates are sent required up a maximum of every 0.5 seconds.
50796
IPO PCPartner
UDP
From an IP Office application (for example Phone Manager or SoftConsole). Used to initiate a session between the IP Office and the application.
50797
IPO TAPI
UDP
From an IP Office TAPI user PC.
50798
(UDP)
UDP
BT Fusion variant. No longer used.
50799
IPO BLF
UDP
Broadcast to the IP Office LAN and the first 10 IP addresses registered from other subnets.
50800
IPO License Dongle
UDP
To the License Server IP Address set in the IP Office configuration.
50801
EConf
UDP
Conferencing Center Service to IP Office.
50802
Discovery
TCP
IP Office discovery from Manager.
50804*
Service Access Protocol
TCP
IP Office configuration settings access.
50805*
TCP
" TLS Secure.
50808*
TCP
IP Office system status access. Used by the IP Office System Status Application (SSA) and IP Office Small Business Center Application (CCR).
50812*
TCP
IP Office security settings access.
50813*
TCP
" TLS Secure.
50814*
TCP
IP Office Enhanced TSPI access. (IP Office 5.0+)
· CDR/SMDR from the IP Office is sent to the port number and IP address defined during configuration and using either TCP or UDP as selected.
Ports
As mentioned, a number of different ports are used for access to IP Office systems. The following table lists some of the ports on which the IP Office control unit listens for different types of access. Indicates a listening port on the IP Office control unit. indicates a port to which the IP Office sends, for example to a PC running an IP Office application.
* Indicates that the port and or protocol can be changed.
Также есть схема удаленного доступа Remote Access
Еще возможно в настройках Манагера стоит посмотреть.
50794
IPO Monitor
UDP
50795
UDP
50796
IPO PCPartner
UDP
50797
IPO TAPI
UDP
50798
(UDP)
UDP
50799
IPO BLF
UDP
50800
IPO License Dongle
UDP
50801
EConf
UDP
50802
Discovery
TCP
50804*
TCP
50805*
TCP
" TLS Secure.
50808*
TCP
50812*
TCP
50813*
TCP
" TLS Secure.
50814*
TCP
Ports
