Как правильно отдавать АОН
chaykaav
Сообщение chaykaav »
Станция IP406 Office. Поднята VoIP Line.
Имеется short code: Code 1N Dial Telephone Number 20.
При трассировке выводит след.
20.05.16 12:03:53-976ms Extension = 3204, Digit dialed, Digit = 1
20.05.16 12:03:53-995ms Call Ref = 1, Originator State = Dialling, Type = User, Destination Type = none
20.05.16 12:03:54-589ms Extension = 3204, Digit dialed, Digit = 0
20.05.16 12:03:54-928ms Extension = 3204, Digit dialed, Digit = 7
20.05.16 12:03:55-202ms Extension = 3204, Digit dialed, Digit = 0
20.05.16 12:03:55-203ms Call Ref = 1, Short Code Matched = System, 1N
20.05.16 12:03:55-206ms My buttons = 1, Call Ref = 1, Originator State = Dialling, Type = User, Destination State = Seized, Type = Target List
20.05.16 12:03:55-243ms Line = 10, Channel = 1, Line Ref = 1004, Q.931 Message = Setup, Call Ref = 1, Direction = From Switch, Calling Party Number = 3204, Called Party Number = 201070
20.05.16 12:03:55-265ms Line = 10, Channel = 1, Q.931 Message = SetupAck, Call Ref = 1, Direction = To Switch
20.05.16 12:03:55-268ms My buttons = 1, Call Ref = 1, Originator State = Dialling, Type = User, Destination State = Seized, Type = Trunk
20.05.16 12:03:55-309ms Line = 10, Channel = 1, Q.931 Message = CallProceeding, Call Ref = 1, Direction = To Switch
20.05.16 12:03:55-313ms My buttons = 1, Call Ref = 1, Originator State = Dialling, Type = User, Destination State = Dialling, Type = Trunk
20.05.16 12:03:55-326ms Line = 10, Channel = 1, Q.931 Message = Alerting, Call Ref = 1, Direction = To Switch
20.05.16 12:03:55-329ms Call Ref = 1, Alerting, Line = 10, Channel = 1
20.05.16 12:03:55-330ms My buttons = 1, Call Ref = 1, Originator State = Ringback, Type = User, Destination State = Outgoing Alerting, Type = Trunk
20.05.16 12:03:58-251ms Extension = 3204, Switchhook, Status = On
20.05.16 12:03:58-253ms My buttons = 1, Call Ref = 1, Originator State = Clearing, Type = User, Destination State = Outgoing Alerting, Type = Trunk
20.05.16 12:03:58-253ms Call Ref = 1, Disconnect from Originator End
А на телефоне определяется как Chayka 3204 > 201070
Вопрос, как убрать >201070 ?
Re: Как правильно отдавать АОН
chaykaav писал(а):Добрый день!
Уверены? Это набираемый номер, а не АОН!
9N
Dial
NSi1234567
-- в линию уйдёт АОН 1234567
Или просто с дисплея телефона убрать набранный номер?
