Expansion complete
[ 2 K L O O P T E S T [ 2 K
Alarm Logging enabled (max entries=8, in use=1)
Audit Logging enabled (max entries=251, in use=135)
NoCacheStaticHeap=3821852 NoCacheDynamicHeap=306916 Overflow=0
Constructor StaticHeap=-63521928 DynamicHeap=50323820
Factory Test Status 00000001
Product Variation Status ffffffff
RTC not initialised or reading is incorrect , Initialise ...
About to create NVConfig
Loaded NVConfig
found FLASH file: ..\modem\zmbin004.s37, len=790
found FLASH file: ..\modem\mcode.bin, len=40000
found FLASH file: ..\vcomp\48105ak.310, len=e2
found FLASH file: ..\vcomp\48105ae3.312.03, len=1ee4e
found FLASH file: ..\platform\onehz.bin, len=3e80
found FLASH file: ding.pcm, len=40a
found FLASH file: ..\vcomp\482ak.311.09, len=10e
found FLASH file: ..\vcomp\48204ae6.311.09, len=1da6a
Re-programming FPGA ...
FPGA Version 0xfe
DCP interface (Hatric v4) detected
Not adding second LAN IFace
htl 00010000 hth 20600000
Broadcom Switch Mode was 0xf5 now 0xf6
EthChipRevId: 0x37 EthPhyId: 0x00370037
MODULES=0xeb
SLOT A: No ISDN Module fitted
SLOT B: ISDN BRI Module Added (must be quad!)
fff0098c 00000000 00000000 00000000 00000000 00000000 00000000 00000000
OSMemPool::Allocate Out of Memory
Programming FPGA ...
FPGA Version 0xFC
CPLD Revs: 0xC1 0xD4
CardID: 0x3A Modules: 0xEB
Expanding MPPC image ...
Expansion complete
Loaded NVConfig
FPGA Version 0xfe
MODULES=0xeb
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
