Всем здравсвуйте! Пытаюсь состыковать Definity CMC-1 и АМТС по
2-ВСК - местные звонки проходят, а вот на межгород после набора 8-ки (слышу акустический запрос АОН от встречной станции) происходит отбой, глянул по list trace station - после 8-ки АОН Definity не отсылает, настройки вот такие:
Настроки Trunk:
Group Number: 20 Group Type: co CDR Reports: y
Group Name: gorod COR: 10 TN: 1 TAC: #31
Direction: outgoing Outgoing Display? n
Dial Access? y Busy Threshold: 255
Queue Length: 0 Country: 15
Comm Type: voice Digit Absorption List:
Prefix-1? y Trunk Flash? n Toll Restricted? y
Trunk Type: loop-start
Group Type: co Trunk Type: loop-start
TRUNK PARAMETERS
Outgoing Dial Type: rotary Cut-Through? n
Trunk Termination: rc Disconnect Timing(msec): 500
Trunk Gain: high
Disconnect Supervision - Out? n
TRUNK FEATURES
Maintenance Tests? y
Data Restriction? n
Suppress # Outpulsing? n
Shuttle? y
Charge Conversion: 1
Decimal Point: none
Currency Symbol: Start Position: 1
Charge Type: units
Per Call CPN Blocking Code:
Per Call CPN Unblocking Code:
Time(sec) to Drop Call on No Answer: 0
Outgoing ANI: 47 Ds1 Echo Cancellation? n
Настройки COR:
Page 1 of 22
CLASS OF RESTRICTION
COR Number: 10
COR Description:
FRL: 0 APLT? y
Can Be Service Observed? n Calling Party Restriction: none
Can Be A Service Observer? n Called Party Restriction: none
Time of Day Chart: 1 Forced Entry of Account Codes? n
Priority Queuing? n Direct Agent Calling? n
Restriction Override: none Facility Access Trunk Test? n
Restricted Call List? n Can Change Coverage? n
Access to MCT? y Fully Restricted Service? n
Group II Category For MFC: 7
Send ANI for MFE? n
MF ANI Prefix: 47 Automatic Charge Display? n
Hear System Music on Hold? y PASTE (Display PBX Data on Phone)? n
Can Be Picked Up By Directed Call Pickup? n
Can Use Directed Call Pickup? n
Group Controlled Restriction: inactive
настройки Multifrequensy-signaling:
MULTIFREQUENCY-SIGNALING-RELATED PARAMETERS
Incoming Call Type: group-ii-mfc
Outgoing Call Type: none
Maintenance Call Type: none NEXT ANI DIGIT
Incoming: send-ani
Maximum Resend Requests:
Received Signal Gain (dB): 0
Transmitted Signal Gain (dB): -3
Request Incoming ANI (non-AAR/ARS)? n
MF Signaling Intercept Treatment - Incoming? n
Private Group II Permissions and Public Interworking? n
change multifrequency-signaling Page 2 of 3
Request Call Category at Start of Call? n
Restart ANI from Caller Category? y
Number of Incoming ANI Digits: 7
Number of Outgoing ANI Digits: 7
Truncate Station Number in ANI: no
Address Digits Include End-of-digits Signal? n
Call Category for Vector ii-digits? n
Request CPN at Start of Call? n
Do Not Send Group B Signals to CO? n
ANI Source for Forwarded & Covered Calls: caller
INCOMING OUTGOING
ANI Available:
ANI Not Available:
INCOMING FORWARD SIGNAL TYPES INCOMING BACKWARD SIGNAL TYPES
(Tones from CO) (Tones to CO)
Group-I Group-II Group-A Group-B
11: ignored 1: normal 1 : next-digit 1 : free
12: ignored 2: normal 3 : end-of-dial 2 : busy
13: ignored 3: normal 5 : send-ani 4 : congestion
14: ignored 4: normal : 7 : intercept
15: ignored 5: attendant : :
6: data-call : :
7: normal : :
8: normal : :
9: normal : :
10: normal : :
11: normal : :
12: normal : :
13: normal : :
14: normal : :
15: normal : :
Может где какую галочку забыл или еще что-то. Заранее спасибо!!!
Проблема отсылки АОН при стыковке СМС и АМТС по R 1.5
