Люди добрые.Помогите с проблемой:
Есть 2 станции "avaya s8510 с cm5.2" и "Квант" соедины друг с другом по CO Trunk.
Проблема состоит в том что званки междуними проходят,но у абонента avaya не слышно сигналов вызова и когда поднимается трубка со стороны Кванта у обоих абонентов тишина не слышат друг друга =( Подскажите кто сталкивался с такой проблемой в чем может быть дело??Или хотябы где копать?
настойки avaya CO Trunk
TRUNK GROUP
Group Number: 108 Group Type: co CDR Reports: y
Group Name: test COR: 92 TN: 1 TAC: 109
Dial Access? n Busy Threshold: 99 Night Service:
Queue Length: 0 Country: 15 Incoming Destination: attd
Comm Type: voice Auth Code? n Digit Absorption List:
Prefix-1? n Trunk Flash? n Toll Restricted? n
Trunk Type: loop-start
Group Type: co Trunk Type: loop-start
TRUNK PARAMETERS
Outgoing Dial Type: rotary Cut-Through? n
Trunk Termination: rc Disconnect Timing(msec): 500
Trunk Gain: high
Disconnect Supervision - In? y Out? n Cyclical Hunt? n
Administer Timers? Y
TRUNK FEATURES
Maintenance Tests? y
Data Restriction? n
Abandoned Call Search? n
Suppress # Outpulsing? n
Shuttle? n
Charge Conversion: 1
Decimal Point: none
Currency Symbol:
Charge Type: units Receive Analog Incoming Call ID: disabled
Per Call CPN Blocking Code:
Per Call CPN Unblocking Code:
Time(sec) to Drop Call on No Answer: 0
Outgoing ANI: 4274500 Ds1 Echo Cancellation? N
ADMINISTRABLE TIMERS
Send Incoming/Outgoing Disconnect Timers to TN465 Ports? n
Incoming Disconnect(msec): 500 Outgoing Disconnect(msec): 500
Outgoing Dial Guard(msec): 1600
Incoming Glare Guard(msec): 1500 Outgoing Glare Guard(msec): 1500
Outgoing Rotary Dial Interdigit(msec): 800
Ringing Monitor(msec): 5200 Incoming Seizure(msec): 500
Outgoing End of Dial(sec): 10 Outgoing Seizure Response(sec): 5
Programmed Dial Pause(msec): 1500
Flash Length(msec): 540
Busy Tone Disconnect? n
END TO END SIGNALING
Tone(msec): 350 Pause(msec): 150
OUTPULSING INFORMATION
PPS: 10 Make(msec): 40 Break(msec): 60 PPM? N
display trunk-group 108 Page 5 of 22
ATMS THRESHOLDS
TTL Type: 105-w-rl Far End Test No:
TTL Vendor: TTL Contact:
Trunk Vendor: Trunk Contact:
Trunk Length:
MARGINAL UNACCEPTABLE
Min Max Min Max
1004 Hz Loss: -2 21 -2 21
-Dev +Dev -Dev +Dev
404 Hz Loss: 9 9 9 9
2804 Hz Loss: 9 9 9 9
Maximum C Message Noise: 55 55
Maximum C Notched Noise: 74 74
Minimum SRL-HI: 0 0
Minimum SRL-LO: 0 0
Minimum ERL: 0 0
Allow ATMS Busyout, Error Logging and Alarming? N
TRUNK GROUP
Administered Members (min/max): 1/1
GROUP MEMBER ASSIGNMENTS Total Administered Members: 1
Port Code Sfx Name Night Mode Type Ans Delay
1: 01D1101 TN747 B attd
Вот что выдаёт трайс:
LIST TRACE
time data
15:47:30 active station 4845 cid 0xe2
15:47:30 tone-receiver 01AXX01 cid 0xe2
15:47:42 dial 97846150 route:ARS
15:47:42 term trunk-group 108 cid 0xe2
15:47:42 route-pattern 2 preference 1 cid 0xe2
15:47:42 seize trunk-group 108 member 1 cid 0xe2
15:47:55 dial 97846150 route:ARS
15:47:55 outpulse done 97846150
15:47:55 tone-receiver 01AXX08 cid 0xe2
15:48:05 tone-receiver 01AXX01 cid 0xe2
15:48:05 active trunk-group 108 cid 0xe2
15:48:10 idle station 4845 cid 0xe2
И после это го тишина с 2 сторон =(((((((((((((
Проблемма со связью по CO Trunk "avaya" и "Кв
У меня такая же связка Квант +Avaya CO Trunk, все работает. Что бросилось сразу в глаза: Dial Access? поставь yes.
Да и еще момент: какое напряжение в линии (знаю что у кванта 4.5V), но для Avaya этого мало, ей надо 9V как минимум. У меня еще стоят дополнительные детекторы отбоя на этих линиях. Проверь сначала всю схему подключения, а потом уж лезь в Asa
