S8300 инсталяция
S8300 инсталяция
Имеется S8300 на нем произведена первичная установка CM, на web адрес 192.11.13.6 по сервисному порту захожу, но требуется логин и пароль craft/damin. Откуда их можно взять?
Sawa
Re: S8300 инсталяция
l login-craftevo писал(а):Имеется S8300 на нем произведена первичная установка CM, на web адрес 192.11.13.6 по сервисному порту захожу, но требуется логин и пароль craft/damin. Откуда их можно взять?
l pas (craftноль один цыфрами)
2. Click Launch Maintenance Web Interface.
3. Click Server Date/Time under Server.
Enter the current date and time and the local time zone.
4. Click Configure Server located in the set of commands available on that web page. The
system displays the Configure Server web page.
To create a login:
1. Ask a customer representative for a login name and password that the customer would like
for the super-user login. If you are a business partner, you can also repeat this procedure to
add the dadmin login.
Note:
Note: Make sure the customer can change this login, its password, or its permissions
later.
2. On the Communication Manager System Management Interface Web page, click Server
(Maintenance) under the Administration menu.
3. Select Security > Administrator Accounts.
The Administrator Accounts screen appears.
4. Select Add Login.
5. Select Privileged Administrator and click Submit.
The Administrator Logins -- Add Login: Privileged Administrator screen appears.
6. Type a login name for the account in the Login name field.
7. Verify the following:
● susers appears in the Primary group field.
● prof18 appears in the Additional groups (profile) field. prof18 is the code for the
customer super-user.
● /bin/bash appears in the Linux shell field.
● /var/home/login name appears in the Home directory field, where login name is the
name you entered in step 6.
8. Skip the fields Lock this account and Date on which account is disabled-blank to
ignore.
9. For the Select type of authentication option, select password.
Note:
Note: Do not lock the account or set the password to be disabled.
10. Enter the password in the Enter password or key field and the Re-enter password or
key field.
11. In the section Force password/key change on next login select no.
12. Click Submit.
The system informs you the login is added successfully.
Спасибо, этот пароль крафта подошел.( странно но м моем мануале этих строчек не было)
Вопрос как теперь зарегистрировать S8300 на шлюзе?
P.S. Я так понимаю alarm на G430 горит из-за этого.
вы почитали бы документы...
в шлюзе
- interface vlan 1
-- ip address _ip_ _mask_
-- exit
- copy running-config starting-config
- reset Y
- ip default-gateway _ip_
- set mgc list _ip_ - задаем ip S8300 или другого сервера. Через пробел можно задать до 4х адресов
- show mgc list -> посмотреть
в шлюзе
- interface vlan 1
-- exit
- reset Y
сервер назначен как MGC и присутствует в списле mgc list, но все равно пишет что не зарегистрирован на шлюзе.Pterodahtil писал(а):вы почитали бы документы...
в шлюзе
- interface vlan 1
-- exit
- reset Y
Cтанция при вводе команды add пишет "invalid entry".
лицензии уже заливали? скрипт для автоконфигурации гейта запускали?
точно такая же трабла была - про скрипт забыли и настраивали гейт в ручную и пропустили указать default gateway для шлюза. Следовательно сервак шлюза не увидел... Отсюда все траблы)
каким логином заходите?evo писал(а):Cтанция при вводе команды add пишет "invalid entry".
после инсталляции станции зайти в web под craft-ом, создать dadmin, заливаем лицензии, pwd файл. заходим в станцию - sav tr, reset sys 4
Да, проблема при настройке GW и думаю из-за 9-го IE.shrike писал(а):лицензии уже заливали? скрипт для автоконфигурации гейта запускали?
Проинициализировал все заново, залил лицензии с другой машины, все ок.
Всем спасибо.
