Но к сожалению звонки ходят только со стороны Аваи. При звонке с Астэриска трассировка транка ничего не показывает.
Заранее спасибо.
Созданы следующие транк и сигналинг группы:
change trunk-group 45 Page 1 of 21
TRUNK GROUP
Group Number: 45 Group Type: sip CDR Reports: y
Group Name: Asterisk COR: 1 TN: 1 TAC: 045
Dial Access? n Night Service:
Queue Length: 0
Signaling Group: 45
Number of Members: 3
change trunk-group 45 Page 4 of 21
PROTOCOL VARIATIONS
Mark Users as Phone? n
Prepend '+' to Calling Number? y
Send Transferring Party Information? n
Send Diversion Header? n
Support Request History? y
Telephone Event Payload Type:
change signaling-group 45 Page 1 of 1
SIGNALING GROUP
Transport Method: tcp
IMS Enabled? n Co-Resident SES? n
Near-end Node Name: procr Far-end Node Name: asterisk
Near-end Listen Port: 5062 Far-end Listen Port: 5060
Far-end Network Region: 1
Far-end Domain:
Bypass If IP Threshold Exceeded? n
Incoming Dialog Loopbacks: eliminate RFC 3389 Comfort Noise? n
DTMF over IP: rtp-payload Direct IP-IP Audio Connections? n
Session Establishment Timer(min): 3 IP Audio Hairpinning? n
Enable Layer 3 Test? n
Alternate Route Timer(sec): 6
