Проблема с CallingNumber в ISDN PRI, помогите разобраться
botanick
Сообщение botanick »
Здравствуйте, есть 3 ISDN Pri потока, схема следующая:
AVAYA CM+G650 -> trunk 5 -> Definity
AVAYA CM+G650 -> trunk 1 -> ТсОП
AVAYA CM+G650 -> trunk 2 -> Cisco
Проблема заключается в передаче CallingNumber через trunk 5 и trunk 2, через trunk 1 в ТсОП АОН уходит нормальный, путем формата public-unknown-numbering.
В trunk 5 и trunk 2 CallingNumber не уходит, уже все перепробовал, не знаю что не учел, вот настройки потоков, и транков,
AVAYA CM+G650 -> trunk 5 -> Definity:
 DS1 CIRCUIT PACK
            Location: 01A07                           Name: Reg Cen old
            Bit Rate: 2.048                    Line Coding: hdb3
      Signaling Mode: isdn-pri
             Connect: pbx                        Interface: user
   TN-C7 Long Timers? n                   Country Protocol: etsi
Interworking Message: PROGress
Interface Companding: alaw                             CRC? n
           Idle Code: 11111111
                                           T303 Timer(sec): 4
                                          Disable Restarts? n
      Slip Detection? n                 Near-end CSU Type: other
  TRUNK GROUP
Group Number: 5                    Group Type: isdn          CDR Reports: y
  Group Name: RegCenter-old               COR: 1        TN: 1        TAC: 7905
   Direction: two-way        Outgoing Display? n         Carrier Medium: PRI/BRI
 Dial Access? n              Busy Threshold: 255  Night Service:
Queue Length: 0
Service Type: tie                   Auth Code? n            TestCall ITC: rest
                         Far End Test Line No:
TestCall BCC: 4
      Group Type: isdn
TRUNK PARAMETERS
         Codeset to Send Display: 6     Codeset to Send National IEs: 6
        Max Message Size to Send: 260   Charge Advice: none
  Supplementary Service Protocol: a     Digit Handling (in/out): enbloc/enbloc
            Trunk Hunt: cyclical
                                                   Digital Loss Group: 13
Incoming Calling Number - Delete:     Insert:                 Format: unk-unk
              Bit Rate: 1200         Synchronization: async    Duplex: full
 Disconnect Supervision - In? y  Out? n
 Answer Supervision Timeout: 0
          Administer Timers? n        CONNECT Reliable When Call Leaves ISDN? n
             XOIP Treatment: auto    Delay Call Setup When Accessed Via IGAR? n
TRUNK FEATURES
          ACA Assignment? n            Measured: none      Wideband Support? n
                                 Internal Alert? n        Maintenance Tests? y
                               Data Restriction? n     NCA-TSC Trunk Member:
                                      Send Name: y      Send Calling Number: y
            Used for DCS? n                            Send EMU Visitor CPN? n
   Suppress # Outpulsing? n    Format: private
 Outgoing Channel ID Encoding: preferred     UUI IE Treatment: service-provider
                                                 Replace Restricted Numbers? n
                                                      Send Connected Number: y
                                                  Hold/Unhold Notifications? n
             Send UUI IE? y     Modify Tandem Calling Number: no
               Send UCID? n
 Send Codeset 6/7 LAI IE? y                         Ds1 Echo Cancellation? n
    Apply Local Ringback? n               US NI Delayed Calling Name Update? n
display aar ana 16
 AAR DIGIT ANALYSIS TABLE
          Dialed           Total     Route    Call   Node  ANI
          String          Min  Max  Pattern   Type   Num   Reqd
    16                    4    4     3        aar          n
display route-pattern 3
  Pattern Number: 3   Pattern Name: Reg Center old
                             SCCAN? n     Secure SIP? n
    Grp FRL NPA Pfx Hop Toll No.  Inserted                             DCS/ IXC
    No          Mrk Lmt List Del  Digits                               QSIG
                             Dgts                                      Intw
 1: 5    0                                                              n   user
Настройки на AVAYA CM+G650 -> trunk 2 -> Cisco идентичны.
Вот трейс звонка на trunk 5:
10:06:01 TRACE STARTED 12/20/2011 CM Release String
10:06:44     dial 1630 route:UDP|AAR
10:06:44     term trunk-group 5    cid 0xc0a
10:06:44     route-pattern  3 preference 1  cid 0xc0a
10:06:44     seize trunk-group 5 member 27  cid 0xc0a
10:06:44     Setup digits 1630
10:06:44     Calling Number & Name NO-CPNumber A.G. Popov
10:06:44     Proceed trunk-group 5 member 27  cid 0xc0a
10:06:44     Alert trunk-group 5 member 27  cid 0xc0a
Вот трейс звонка на trunk 2 с Cisco:
4w0d: ISDN BR1/1 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Called num 5041
4w0d: ISDN BR1/1 Q931: TX -> SETUP pd = 8  callref = 0x0D
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Display i = 'A.G. Popov'
        Called Party Number i = 0xA1, '5041'
                Plan:ISDN, Type:National
        Sending Complete
4w0d: ISDN BR1/1 Q931: RX <- CALL_PROC pd = 8  callref = 0x8D
        Channel ID i = 0x89
4w0d: ISDN BR1/1 Q931: RX <- ALERTING pd = 8  callref = 0x8D
        Channel ID i = 0x89
В чем может быть проблема?
Может быть в private-numbering ?
display private-numbering 0                                     Page   1 of   2
                           NUMBERING - PRIVATE FORMAT
Ext Ext            Trk        Private          Total
Len Code           Grp(s)     Prefix           Len
                                                     Total Administered: 0
                                                        Maximum Entries: 540
Помогите пожалуйста, уже 3 для сижу в интернетах ищу решение.
Заранее благодарен!
Re: Проблема с CallingNumber в ISDN PRI, помогите разобратьс
ch priv - настройте
olle
Сообщение olle »
li pu я бы глянул все же
botanick
Настроил ch priv
 4  1              2-5                         4     Total Administered: 1
В trunk 5 подключенный к AVAYA CPNumber начал улетать, а вот в trunk 3 подключеный к Cisco почему то нет, настройки одинаковые:
display trunk-group 3                                           Page   1 of  21
                                TRUNK GROUP
Group Number: 3                    Group Type: isdn          CDR Reports: y
  Group Name: KSPD                        COR: 1        TN: 1        TAC: 7903
Queue Length: 0
TestCall BCC: 4
display trunk-group 3                                           Page   2 of  21
      Group Type: isdn
TRUNK PARAMETERS
display trunk-group 3                                           Page   3 of  21
TRUNK FEATURES
               Send UCID? n
Вот, кто просил li pub:
list public-unknown-numbering                                          Page   1
                     NUMBERING - PUBLIC/UNKNOWN FORMAT
                                                    Total
         Ext Ext           Trk       CPN             CPN
         4   1             1         399800          6
         4   1002          1         399802          6
         4   1003          1         399803          6
         4   1004          1         399804          6
         4   1006          1         399816          6
         4   1007          1         399819          6
         4   1008          1         399818          6
         4   1009          1         399809          6
         4   1010          1         399801          6
         4   1011          1         399811          6
         4   1012          1         399812          6
         4   1013          1         399813          6
         4   1014          1         399814          6
         4   1015          1         399815          6
         4   1016          1         399825          6
и т.д.
Завтра попробую сделать public на этот транк и вписать в него, ео это как-то коряво получается : )
В чем может быть трабл?
olle
Сообщение olle »
Надеюсь, что далее в "и т.д." вся эта красота прописана и для 2 и для 5 транков?
зачем li pub если в транке прописан privat формат?
в сторону cisco
Codeset to Send Display: 0
А еще за Supplementary Service Protocol: a бьют, и больно.
botanick
Помогло:
                                                    Total
         Ext Ext           Trk       CPN             CPN
         4   1             1         399800          6
         4   1             2-5                       4
Почему - так и не понял, т.к. формат стоит private.
С этим соглашусь, но почему-то поток на etsi не хотел работать.
