Avaya IP Office 500. Ошибка SIP - code 404 to method INVITE
blazer2k
Сообщение blazer2k »
Помогите пожалуйста. Настраиваю связку Avaya IPO 500 + Microsoft Lync Server.
При попытке позвонить на внешний номер Avaya показывает следующее:
670286mS SIP Rx: TCP 192.168.0.94:52740 -> 192.168.0.7:5060
INVITE sip:98916xxx0379@192.168.0.7;user=phone SIP/2.0
FROM: "Литвинский Андрей Андреевич"<sip:4957872992@lync.xxx.ru;user=phone>;epid=F182909C87;tag=fa8db7831f
TO: <sip:98916xxx0379@192.168.0.7;user=phone>
CSEQ: 34 INVITE
CALL-ID: c731b9e9-1a15-4c2f-935e-8c3499717c97
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP 192.168.0.94:52740;branch=z9hG4bK62ddc3c0
CONTACT: <sip:lync.xxx.ru:5060;transport=Tcp;maddr=192.168.0.94;ms-opaque=95af430f822a0cc5>
CONTENT-LENGTH: 338
SUPPORTED: 100rel
USER-AGENT: RTCC/4.0.0.0 MediationServer
CONTENT-TYPE: application/sdp
ALLOW: ACK
Allow: CANCEL,BYE,INVITE,PRACK,UPDATE
v=0
o=- 5 1 IN IP4 192.168.0.94
s=session
c=IN IP4 192.168.0.94
b=CT:1000
t=0 0
m=audio 55650 RTP/AVP 97 101 13 0 8
a=rtcp:55651
a=label:Audio
a=sendrecv
a=rtpmap:97 RED/8000
a=fmtp:101 0-16
a=rtpmap:13 CN/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=ptime:20
670287mS Sip: SipTCPUser forwarding to Trunk!!!
670289mS Sip: SIPDialog TXN : Decoding of message Succeded 1
670290mS Sip: Create Incoming EndPoint voip
670290mS CMCallEvt: 0.1027.0 -1 BaseEP: NEW CMEndpoint f569869c TOTAL NOW=3 CALL_LIST=1
670290mS PRN: Created MH f569796c parent 0.1027.0 -1 SIPTrunk Endpoint
670290mS Sip: License, Valid 1, Available 4, Consumed 0
670291mS Sip: CheckLineMonitors on SIP Endpoint - KEY & LAMP for SIP Trunk!
670291mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) ExtractCallIdFrom Message: Call Id value c731b9e9-1a15-4c2f-935e-8c3499717c97
670291mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) ExtractCallerFromMessage: From Tag is fa8db7831f
670292mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) No Accept Header
670293mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) SendSIPResponse: INVITE SENT TO 192.168.0.94 5060
670293mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) Sending code 100 to method INVITE
670293mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) SendSIPResponse, Number of Tag Count, 0
670294mS SIP Tx: TCP 192.168.0.7:5060 -> 192.168.0.94:5060
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.0.94:52740;branch=z9hG4bK62ddc3c0
From: "Литвинский Андрей Андреевич" <sip:4957872992@lync.xxx.ru;user=phone>;tag=fa8db7831f;epid=F182909C87
To: <sip:98916xxx0379@192.168.0.7;user=phone>;tag=8ddc5a2387ec6168
Call-ID: c731b9e9-1a15-4c2f-935e-8c3499717c97
CSeq: 34 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, INFO
Content-Length: 0
670294mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) INVITE Received ep 18.1027.1 -1 SIPTrunk Endpoint(f569869c), dialog f5697a78
670295mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) UpdateSIPCallState SIPDialog::INITIAL(0) -> SIPDialog::INVITE_RCVD(10)
670295mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) Present Call, no match (98916xxx0379) from URI in To header.
670295mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) Present Call, no match from URI in Request Line
670295mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) SendSIPResponse: INVITE SENT TO 192.168.0.94 5060
670296mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) Sending code 404 to method INVITE
670296mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) SendSIPResponse, Number of Tag Count, 1
670296mS SIP Tx: TCP 192.168.0.7:5060 -> 192.168.0.94:5060
SIP/2.0 404 Not Found
CSeq: 34 INVITE
Content-Length: 0
670297mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) UpdateSIPCallState SIPDialog::INVITE_RCVD(10) -> SIPDialog::FINAL(40)
670297mS Sip: SIP Line (18): Freed Txn Key 2016
670301mS RES: Thu 15/3/2012 15:43:52 FreeMem=75513804(2) CMMsg=4 (4) Buff=200 960 1000 7424 5 Links=20729
670301mS RES2: RTEngine=0, CMRTEngine=0, Timer=54, Poll=0, Ready=1, CMReady=0, CMQueue=0, VPNNQueue=0
670303mS SIP Rx: TCP 192.168.0.94:52740 -> 192.168.0.7:5060
ACK sip:98916xxx0379@192.168.0.7;user=phone SIP/2.0
FROM: "Литвинский Андрей Андреевич"<sip:4957872992@lync.norbit.ru;user=phone>;tag=fa8db7831f;epid=F182909C87
TO: <sip:98916xxx0379@192.168.0.7;user=phone>;tag=8ddc5a2387ec6168
CSEQ: 34 ACK
MAX-FORWARDS: 70
CONTENT-LENGTH: 0
670303mS Sip: SipTCPUser forwarding to Trunk!!!
670304mS Sip: SIPDialog TXN : Decoding of message Succeded 1
670305mS Sip: Find End Point 18.1027.1 -1 SIPTrunk Endpoint (f569869c) Sip CallId c731b9e9-1a15-4c2f-935e-8c3499717c97
670305mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) Process SIP request dialog f5697a78, method ACK in state SIPDialog::FINAL(40)
671306mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) EPTerminationTimeout, about to delete endpoint
671306mS Sip: SipTCPUser has 4 dialog open
671306mS Sip: 18.1027.1 -1 SIPTrunk Endpoint(f5697a78) SIPDialog destructor ... f5697a78
671306mS CMCallEvt: 18.1027.1 -1 SIPTrunk Endpoint: StateChange: END=X CMCSIdle->CMCSDelete
671306mS Sip: ~SipTrunkEndpoint 18.1027.1 -1 SIPTrunk Endpoint
671307mS PRN: Destroyed MH f569796c parent unknown
671307mS CMTARGET: 18.1027.1 -1 BaseEP: ~CMTargetHandler
671308mS CMCallEvt: 18.1027.1 -1 BaseEP: DELETE CMEndpoint f569869c TOTAL NOW=2 CALL_LIST=1
677005mS PRN: ConferDSP is alive
Во вложенных файлах настройки SIP на Avaya. Заранее спасибо за помощь.
avaya2.tiff
avaya2.tiff (140.26 КБ) 11376 просмотров
avaya1.tiff
avaya1.tiff (149.88 КБ) 11376 просмотров
Re: Avaya IP Office 500. Ошибка SIP - code 404 to method INV
я так понимаю, это ответ от линка?
CyMac6poD
Сообщение CyMac6poD »
Перезалейте картинки во что-то более удобоваримое чем тифф. и для уточнения - это трейс входящего звонка на авайю? 0.7 - авайа, 0.94 - линк. так?
blazer2k
Спасибо всем откликнувшимся!
1921.168.0.94 - Lync
192.168.0.7 - Avaya
Сама ошибка, как я понимаю, кроется тут:
Нет маршрута на 98916xxx0379. По крайней мере, из транка Lync.
Скриншоты перезалил.
CyMac6poD
Вы звоните от линка(4957872992) на авайку(98916xxx0379).
Present Call, no match (98916xxx0379) from URI in To header - насколько я понимаю, это значит, что с данным входящим номером не совпадает ни одна запись в SIP URI. Соответственно станция не маршрутизировать звонок и пишет
Sending code 404 to method INVITE - т.е. недоступно. пересмотрите записи в SIP URI и было бы неплохо увидеть трейс исходящего звонка с авайи
blazer2k
на первом же скрине приведены мои настройки URI. Во всех полях звездочка.
CyMac6poD
blazer2k писал(а):на первом же скрине приведены мои настройки URI. Во всех полях звездочка.
И, собственно что она должна означать? Типа маски для любого номера? По-моему так не работает. попробуйте указать конкретный номер. это ведь авторизационные записи, по ним регистрация(если есть) идет.
andrkv
Сообщение andrkv »
Всё правильно сделано.
Только ещё в Incoming CAll Route для этой линии в Destination надо поставить "." (точку)
точка вызов пойдёт через шот коды
Настрою ваш IPO
