Есть IPO 406 v2. По не известным никому причинам перестал работать поток PRI.
Трассировка исходящего звонка
IE CMIERespondingPartyKName (229) ФАКС
IE CMIERespondingPartyNumber (230)(P:100 S:100 T:101 N:100 R:4) number=218
IE CMIEDeviceDetail (231) LOCALE=rus HW=8 VER=4 class=CMDeviceStdPhone type=3 number=330 channel=0 rx_gain=32 tx_gain=32 ep_callid=1002 ipaddr=192.168.7.141 apps=0
265065mS CMCallEvt: 0.1002.0 1 ФАКС.0: StateChange: END=A CMCSIdle->CMCSDialInitiated
265065mS CMExtnEvt: v=8 State, new=Connected old=Idle,0,0,ФАКС
265065mS CMTARGET: 0.1002.0 1 ФАКС.0: LOOKUP CALL ROUTE: type=100 called_party= sub= calling=218 dir=out complete=0 ses=0
265066mS CMTARGET: 0.1002.0 1 ФАКС.0: ADD TARGET (N): number= type=100 depth=1 nobar=1 setorig=1 ses=0
265066mS CMCallEvt: 0.1002.0 1 ФАКС.0: StateChange: END=A CMCSDialInitiated->CMCSDialling
265067mS CMExtnEvt: v=8 State, new=Dialling old=Connected,0,0,ФАКС
265067mS CMExtnTxC: v=218
CMSetupAck
Line: type=NoLine 0 Call: lid=0 id=1002 in=0
265067mS CMExtnTx: v=218, p1=0
CMSetupAck
Line: type=AnalogueExtn 4 Call: lid=0 id=8 in=0
BChan: slot=10 chan=10
UUI type=Local [......2Pd.] [0x01 0xff 0x00 0x00 0x01 0x02 0x32 0x50 0x64 0x00 ]
Timed: 10/07/12 12:31
265068mS CD: CALL: 0.1002.0 BState=Idle Cut=1 Music=3.0 Aend="ФАКС(218)" (10.10) Bend="" [] (0.0) CalledNum= () CallingNum=218 (ФАКС) Internal=1 Time=9 AState=DialInitiated
265069mS CD2: CALL:S 0.1002.0,0.1003.0,9,0,1,3,0,0,ФАКС(218),,,10.10,0.0,100.100,,100.101,218,,,100,,100,,0,16,0,0,0.0,,,,,,,1,9,0,0,0,0,rus,,0,,0,0,0,0,,1,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
265070mS CMMap: a=10.10 b=0.0 D1
265525mS RES: Tue 10/7/2012 12:31:47 FreeMem=45225200(2) CMMsg=2 (2) Buff=100 612 500 1068 5 Links=344
265525mS RES2: RTEngine=0, CMRTEngine=0, Timer=46, Poll=0, Ready=0, CMReady=0, CMQueue=0, VPNNQueue=0
269525mS IP Routing Table - section 1
Destination Netmask Gateway Interface Metric Type
255.255.255.255 255.255.255.255 192.168.7.141 LAN1 1 I
224.0.0.0 240.0.0.0 192.168.7.141 LAN1 1 I
192.168.7.0 255.255.255.0 192.168.7.141 LAN1 1 I
192.168.99.0 255.255.255.0 0.0.0.0 RemoteManager 1 S
269618mS CMCallPkt: v=0
CMInformation
Called[7] Type=Default (100) Reason=CMDRdirect
269618mS CMExtnRx: v=218, p1=0
CMInformation
269618mS CMExtnRxC: v=218
CMInformation
Line: type=AnalogueExtn 4 Call: lid=0 id=1002 in=0
IE CMIERespondingPartyName (228) ФАКС
269620mS CMMap: a=10.10 b=0.0 D0
270034mS CMCallPkt: v=0
CMInformation
Called[1] Type=Default (100) Reason=CMDRdirect
270035mS CMExtnRx: v=218, p1=0
CMInformation
270035mS CMExtnRxC: v=218
CMInformation
270479mS CMCallPkt: v=0
CMInformation
Called[4] Type=Default (100) Reason=CMDRdirect
270480mS CMExtnRx: v=218, p1=0
CMInformation
270480mS CMExtnRxC: v=218
CMInformation
271132mS CMCallPkt: v=0
CMInformation
Called[2] Type=Default (100) Reason=CMDRdirect
271133mS CMExtnRx: v=218, p1=0
CMInformation
271133mS CMExtnRxC: v=218
CMInformation
271133mS CMTARGET: 0.1002.0 1 ФАКС.0: CancelTimer CMTCDelayedProcessing
271134mS CMTARGET: 0.1002.0 1 ФАКС.0: LOOKUP CALL ROUTE: type=100 called_party=7142 sub= calling=218 dir=out complete=0 ses=0
271134mS CMTARGET: 0.1002.0 1 ФАКС.0: ADD TARGET (N): number=7142 type=100 depth=1 nobar=1 setorig=1 ses=0
271135mS CMTARGET: 0.1002.0 1 ФАКС.0: DEF SC: 7142 0 sc=type=Dial code=?, num=.
271135mS CMARS: CMARSHandler::FindActiveARSByGroupID GroupID=50
271135mS CMARS: CMARSHandler::MakeCallTarget - Called Number: 7142
271136mS CMCallEvt: 0.1004.0 -1 BaseEP: NEW CMEndpoint feb19ce4 TOTAL NOW=3 CALL_LIST=1
271136mS CMTARGET: 0.1002.0 1 ФАКС.0: CancelTimer CMTCDialToneTimeout
271136mS CMTARGET: 0.1002.0 1 ФАКС.0: INITIAL TARGETING SUCCEEDED
271137mS CMTARGET: 0.1002.0 1 ФАКС.0: GetNoAnswerTimer:15
271137mS CMCallEvt: 0.1003.0 1 TargetingEP: StateChange: END=B CMCSIdle->CMCSOffering
271138mS CMCallEvt: 0.1004.0 1 ARS for Main: StateChange: END=T CMCSIdle->CMCSOffering
271139mS CMCallEvt: 0.1003.0 1 TargetingEP: RequestEnd 0.1004.0 1 ARS for Main
271139mS CMTARGET: 0.1002.0 1 ФАКС.0: CancelTimer CMTCNoAnswerTimeout
271139mS CMCallEvt: 0.1004.0 1 ARS for Main: StateChange: END=B CMCSOffering->CMCSOverlapRecv
271140mS CMARS: FORM: Main - Received Number: 7142
271140mS CMARS: FOUND A SHORT CODE - short_code: ? - Tel: . - Called_Party: 7142 - Line Group Id: 2
271140mS CMARS: CMARSHandler::FindActiveARSByGroupID GroupID=2
271141mS CMLRQ: CMLRQHandler::FindActiveLRQByGroupID GroupID=2
271141mS CMLineTx: v=5
CMRestart
Line: type=Q931Line 5 Call: lid=0 id=-1 in=0
Display [rus]
Locale: rus
271141mS CMTARGET: Problem with Line Id: 5 - preselected: 00000000, Unlicenced: 0, OperationalTest: 1, NewCallResourceCheck: -1
271143mS CMARS: LINE with group ID: 2 HAS NO CHANNEL: 34 - ATTEMPT OTHER TARGETS
271143mS CMLineTx: v=5
CMRestart
Display [rus]
Locale: rus
271144mS CMTARGET: Problem with Line Id: 5 - preselected: 00000000, Unlicenced: 0, OperationalTest: 1, NewCallResourceCheck: -1
271144mS CMARS: No Alternate ARS Or User Priority lower than ARS Priority - Remain on the Current Form: Main
271145mS CMARS: CMARSTargetingBusy
271145mS CMCallEvt: 0.1004.0 1 ARS for Main: StateChange: END=B CMCSOverlapRecv->CMCSAccept
271145mS CMCallEvt: 0.1002.0 1 ФАКС.0: StateChange: END=A CMCSDialling->CMCSRingBack
271146mS CMExtnEvt: v=8 State, new=Alerting old=Dialling,0,0,ФАКС
271146mS CMExtnTxC: v=218
CMProgress
IE CMIEProgressIndicator (30) cs=CMCSITUT (0), loc=CMLUser (0), pd=CMPDInbandPattern (8)
Display [WAITING_FOR_LINE]
271146mS CMExtnTx: v=218, p1=0
CMProgress
271147mS CMCallEvt: 0.1003.0 -1 TargetingEP: StateChange: END=X CMCSOffering->CMCSDelete
271147mS CMCallEvt: 0.1003.0 -1 BaseEP: DELETE CMEndpoint feb223e8 TOTAL NOW=2 CALL_LIST=1
271148mS CD: CALL: 0.1002.0 BState=Ringing Cut=3 Music=0.0 Aend="ФАКС(218)" (10.10) Bend="" [] (0.0) CalledNum=7142 () CallingNum=218 (ФАКС) Internal=1 Time=6089 AState=Ringing
Цветом я выделил кусочек, который меня смутил особенно. правда я не знаю, что с ним делать? Дополнительные лицензии на PRI? судя по всему их тут и не было никогда. Систем статус показывает Administering channels -0, менял карту PRI - та же фигня
Есть идеи?
PRI на IPO 406v2
Re: PRI на IPO 406v2
уберите все лишнее в фильтре, оставьте закладку ISDN там Layer 3
закладка Call -> Short Code Msgs
Что там у вас с лицензиями?
Все уладилось. у провайдера были битые модемы. Спасибо за внимание))
