Проблема H323 транка
BonScott
Сообщение BonScott »
Подскажите, пожалуйста! Что за "denial event 1192" в трэйсе:
13:27:54 active station 1556 cid 0x1c65
13:27:54 G711A ss:off ps:20 rn:1/1 10.123.11.50:3142 10.123.11.27:2552
13:27:54 xoip: fax:Relay modem:off tty:US 10.123.11.27:2552 uid:0x8bb2
13:27:57 dial 06629 route:AAR
13:27:57 term trunk-group 98 cid 0x1c65
13:27:57 route-pattern 98 preference 1 cid 0x1c65
13:27:57 seize trunk-group 98 member 2 cid 0x1c65
13:27:57 Calling Number & Name 6629 NO-CPName
13:27:57 Proceed trunk-group 98 member 2 cid 0x1c65
13:28:02 denial event 1192: Temporary failure D1=0x8bb2 D2=0xf29
13:28:02 idle trunk-group 98 member 2 cid 0x1c65
13:28:05 idle station 1556 cid 0x1c65
vsorokin
Re: Проблема H323 транка
Сообщение vsorokin »
Из Avaya Aura™ Communication Manager Denial Events (03-602793,Issue 1,May 2009):
1192 Temporary failure Temporary failure.
See Cause Value 41 on page 32.
UID DIAG/LOC/CV
Cause Value 41
[0x29/0xA9] -
Temporary Failure
The call was not completed because the ISDN network is not functioning correctly. The
condition is not likely to last a long period of time. If the user attempts the call again it will
probably complete.
Cause Value 41 might also indicate:
• The failure of channel negotiation at the terminating interface.
• A data link layer malfunction has occurred locally or at the remote network interface.
• The call is being cleared as a result of one or more protocol errors at the remote network
interface.
See also Cause Value 63 on page 40 and Cause Value 79 on page 43.
Cause Value 63
[0x3F/0xBF] -
Service or option not available, unspecified
This Cause Value indicates that the requested service or option is unavailable when no other
cause in the Service or option not available class applies.
As an implementation option, this Cause Value shall either be passed to the user or mapped to
Cause Value 41 (Temporary Failure) when it is received at a CO as part of SS7 call handling.
Communication Manager does not originate Cause Value 63.
Cause Value 79
[0x4F/0xCF] -
Service or option not implemented, unspecified
The call could not be completed because the equipment sending this Cause Value has not
implemented a service, feature, or supplementary service requested by the user, and none of
the other Cause Values in the Service or option not implemented class apply.
As an implementation option, this Cause Value might be mapped to Cause Value 41 (Temporary
Communication Manager does not originate Cause Value 79.
Перевод:
Значение причины 41
[0x29/0xA9] -
Временный отказ
Вызов не был завершен, потому что сеть ISDN не функционирует правильно.
условие вряд ли продлится длительный период времени. Если пользователь будет делать попытку вызова снова, то он будет
вероятно, завершенный.
Значение причины 41 могло бы также указать:
• Отказ согласования канала в завершающемся интерфейсе.
• Неправильное функционирование канального уровня произошло локально или в удаленном сетевом интерфейсе.
• Вызов очищается в результате одной или более ошибок протокола в удаленной сети
интерфейс.
См. также Значение Причины 63 на странице 40 и Значении Причины 79 на странице 43.
Значение причины 63
[0x3F/0xBF] -
Служба или опция, не доступная, неуказанная
Это Значение Причины указывает, что требуемая служба или опция недоступны когда никто другой
причина в Службе или опции не доступный класс применяется.
Как опция реализации, это Значение Причины должно или быть передано пользователю или отображено на
Значение причины 41 (Временный отказ), когда это получено в CO как часть обработки вызовов SS7.
Менеджер по передаче не порождает Значение Причины 63.
Значение причины 79
[0x4F/0xCF] -
Служба или опция, не реализованная, неуказанная
Вызов не мог быть завершен, потому что оборудование, отправляющее это Значение Причины, не имеет
реализованный служба, функция или дополнительная услуга, которую требует пользователь и ни один из
другие Значения Причины в Службе или опции не реализованный класс применяются.
Как опция реализации, это Значение Причины могло бы быть отображено, чтобы Вызвать Значение 41 (Временный
Отказ), когда это получено в CO как часть обработки вызовов SS7.
Менеджер по передаче не порождает Значение Причины 79.
