Как перевести Manager на английский
CyMac6poD
Сообщение CyMac6poD »
Доброго времени суток, коллеги. Поработал с cisco, ужаснулся и вернулся обратно в AVAYA. :D
Собственно вопрос - как родной Manager перевести на родной английский. В темах вроде не нашел, если уже где-то упоминалось - сорри за оффтоп
Re: Как перевести Manager на английский
1.4 Changing the IP Office Manager Language
The IP Office Manager application can run in US English, UK English, Chinese (Simplified), French, German,
Brazilian Portuguese, Dutch, Italian, Russian and Mexican Spanish. By default it tries to use the best match to the
PC's regional location settings, otherwise it will use UK English.
The process below can be used to run IP Office Manager in one of its supported languages. However it does not change
the language used for help file content.
1. Create a Windows shortcut to the IP Office Manager application .exe file. By default this file is located in C:
\Program Files\Avaya\IP Office\Manager\Manager.exe.
2. Right-click on the shortcut and select Properties.
3.The Target field can be used to specify the locale setting that IP Office Manager should use.
•For example, for Italian the Target should have -locale:it-IT added to the end. For example: "C:\Program
Files\Avaya\IP Office\Manager\Manager.exe" -locale:it-IT.
4. The available locales for IP Office Manager are:
IP Office Manager Language Shortcut Locale Setting
Brazilian Portuguese -locale:pt-Br
Chinese (Simplified) -locale:zh-Hans
Dutch -locale:nl-NL
French -locale:fr-FR
German -locale:de-DE
Italian -locale:it-IT
Mexican Spanish -locale:es-MX
Russian -locale:ru-RU
US English -locale:en-US
5. Click OK.
6.IP Office Manager should now run in the selected language when launched using the updated shortcut.
